Question about Ripcurl Ultimate Oceansearch Watch
What causes my Ultimate Oceansearch watch to reset itself multiple times a day / week?
I have had the battery replaced and had the watch pressure tested - the watch resets itself constantly for no apparent reason. Time reverts to 12h00 and date reverts to 01/01. Tides and compass also reset.
My casio pro trek 2894 is frozen it shows op en ontop and when i press the setting button it resets time to 12h00
Hi
Have you checked that all buttons when pressed come in and out easily?
Sometimes the little spindles that press the contacts inside the watch do not come out completely and remain "pressed" even if the button appears to be "out"
Clean the watch, with particular attention to the buttons area so they can move easily in and out. If this does not do the trick, open the watch with great care not to damage the threads on the plastic case and visiually inspect if the buttons travel easily in and out and that all springs if fitted are sound. Remove and replace the batteries with new ones (DO NOT use bargain batteries from that "auction site")
and reset the watch.Try again, if ok carefully clean the back seal apply a little vaseline to the top of the seal and close the case. DO NOT over tighten the screws as this will damage the plastic thread and the watch will not seal properly and will be likely to flood with moisture. Good luck
Jan 25, 2017 | Casio Watches
How do i turn my watch on or should it of came turned on
You should have to turn the watch on. If it is not on, then you need a new battery.
Dec 24, 2013 | Ripcurl Rip Curl Trestles Oceansearch Tide...
Battery
this meens it needs a new battery
Jul 08, 2013 | Ripcurl Rip Curl Trestles Oceansearch Tide...
After I changed a battery on R0614ZM TERNER watch, the display went berzerck and then blank altogether. Any ideas at all?
Some watches have a "reset" button or combination of buttons that must be pushed to clear all the electronic registries on the watch's little computer after you replace the battery. You might try taking off the watch back and seeing if your watch has this requirement. Even then, it's not always a perfect solution. Last week, I replaced the battery in a watch that had been dead for some time. The watch appeared to come alive again when I put the new battery in, but when I pushed the reset pin (on this movement, it was on the watch movement itself, next to the battery), the entire watch went dead. Nothing I did would wake it up. I removed the battery, waited 30 seconds, then re-inserted the battery. Problem solved; the watch powered up, and I was able to set the time and access all functions again.
On some digital watches from the 1980s, after replacing the batteries, you were supposed to push and hold all the external buttons for a few seconds to reset the watch. I don't think manufacturers still make watches that respond to this, but it is easier to try than taking off the back and re-installing the battery.
May 10, 2011 | Watches
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
IT IS AN ORVIS AUTOMATIC AND IT STARTS AND STOPS AND DOESN'T KEEP CORRECT TIME.
Thank you for contacting FixYa.
When you first receive your automatic watch, you must give the watch an initial pre-wind. If you wear it everyday, it will continue to wind itself on your wrist when you move around and walk. If you stop wearing it for more than approximately 2 days, the watch will need to be reset, but will then automatically wind itself once you start wearing it again. The disadvantage to this is pretty clear. Your watch does not t keep time if you do not wear it constantly. The advantages are that you will never have to replace a battery, the watch keeps great time when it is running, and most of all, this type of movement is exactly what the originals use! If your Automatic is losing or gaining time in a 24-hour period the watch needs to be adjusted. All of our automatics have an adjustment screw on the movement just like the originals. Any local jeweler can service these watches.
Best regards! Jewel
Aug 25, 2010 | Orvis Watches
(cj1110.ba0576) Wrist Watch: the second hand on my tag watch is sticking for a ...
you don't have to change battery, as it was still at the right time. There might be some other reason that your watch behave like that. A test on the capacitor of your watch is needed, if this still strong then i suggest you should have your watch General Overhauled by a technician.
May 18, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Ripcurl Ultimate Oceansearch Watch Logo
Top Ripcurl Watches Experts
Tom Chichester
Buddy lotter
Buddy lotter
Are you a Ripcurl Watch Expert? Answer questions, earn points and help others
