Question about HP Office Equipment & Supplies
Hp 1213 mfp keys not working
Everything is fine in hp 1213mfp,printer inintializing,after that redy comes but then no key works.
Altoire
  • 24 Answers
SOURCE: HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Posted on Dec 31, 2006
till death
  • 6 Answers
SOURCE: HP 4101 MFP PRINTER 30-1.19 SCAN COPY FAILURE
1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over
Posted on May 04, 2009
ajuhere81
  • 256 Answers
SOURCE: hp laserjet m1005 mfp printer, but it's cd was crack
You can downlaod the original drivers and software from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1839459&prodTypeId=18972&prodSeriesId=1839458&swLang=8&taskId=135&swEnvOID=228
Posted on Aug 29, 2009
  • 313 Answers
SOURCE: LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
Posted on May 07, 2010
  • 123 Answers
SOURCE: hi, I have problem with printer hp 1522n MFP that ...
Try doing an NvRam on the printer (Hard Reset):
1. Turn the printer off
2. Press and hold the right arrow and the cancel button
3. Turn the printer on while still holding those buttons
4. Keep holding them until you see a message that say "permanent storage init"
This should clear that error message
You must be using new hp original supplies otherwise the unit will not recognize the cartridge.
Try checking with flash light if theres a broken piece or a small piece of paper that could be blocking the printer sensors before you reinstall the cartridge
Posted on Sep 07, 2010
Hp LJ m9040 MFP
Hi
Please try below
https://support.hp.com/au-en/document/c01471110
HP LaserJet M9040 and M9050 MFP Series Control Panel Calibration HP...
Oct 13, 2017 | Office Equipment & Supplies
Scan note working (Hp Laserjet M5035 MFP)
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Mar 20, 2011 | HP LaserJet M5035 MFP Printer
Tengo una impresora de Modelo Hp LaserJet M1522n MFP presenta el siguiente mensaje de error. Error de memoria consum: 10.1000 pareciera ser por que el cartucho no es original, pero lo he comprado con...
It is possible. The message is caused because the printer cannot read the little chip that is on the cartridge. Usually replace the toner will fix the issue (specially if its not hp). In your case it might be the reader that is not working. Try taking the cartridge and paper out. Then reset the printer by turning it off and press and hold the down arrow and cancel. Then turn it on and wait for the message ''permanent storage init'' then release the keys and will get back to ready.
Aug 30, 2010 | HP LaserJet M1522nf Multifunction Printer...
How do i scan images using the hp 4730 mfp
check under general reference (link below). it should mention how to fax, e:mail and copy. if you copy to file / pc that should work as the scanner.
otherwise make sure the "scanner" facility is installed as some MFP's do not come with all facilities installed. (and therefore may not give the option on the screen.)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=468688
Jul 21, 2010 | HP LaserJet 4730 MFP Printer
Minus Key doesn't work. all other keys work fine.
Please define the "-" minus key. Are you talking about the PC's keyboard or a button on the printer's front panel.
Also, what is the make and model of the printer.
Don
Feb 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
My HP Laserjet colour CM1015 MFP printer does not pick up the paper. It doesnt calibrate either and I dont know why
I eliminated everything except two new non HP majenta and cyan cartridges. I removed the cyan cartridge and replaced it with an empty magenta cartridge, giving me 2 magenta cartridsges and althought it didnt printy, it staretd to pick up the paper so paper feed was working. I knew then that the cyan cartridge was faulty and changed it. All works now
Nov 02, 2009 | HP LaserJet CM1015 MFP All-In-One Printer
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
