Question about Coffee Makers & Espresso Machines
Kenwood kmix problems
My kenwood kmix coffee machine has just gone faulty. The water isnt coming out of the back and its making a gurgling spitting sound
SOURCE: PROBLEM WITH LOW FLOW/PRESSURE IN GAGGIA COFFEE DELUX COFFEE MAKER
the most likely reason for poor flow through the brewhead is a blockage in the outlet valve.the outlet valve is behind the shower disc holding plate and can be removed with 13mm socket. a straightened paper clip needs to be insrted in the outlet to clear any internal blockage,then pump water through. if the outlet valve splits in two ensure the rubber bung is inserted upwards.once refitted all should be fine
Posted on Aug 07, 2008
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Posted on Mar 02, 2009
  • 1089 Answers
SOURCE: leaking coffee grounds and water
HI
There should be a small amount of coffee residue and about an oz. of water going into the drip tray. This is the pressure relief process, when the machine finishes the coffee making. If it didn't release the pressure thhis way you could have an explosion of coffee when it cycles back.
Posted on Jan 06, 2010
  • 5 Answers
SOURCE: We pour the water into
It sounds like it is clogged.
In the manual it explains how to descale with white vinegar. Another thing to do is to take a straightened paper clip and unclog all openings where water goes through. Taking out the k-cup holder and cleaning is also recommended.
Keurig 866-901-2739 will walk you through these steps. They are very nice and this is what I did when I was having trouble with mine.
Good luck.
Posted on Feb 04, 2011
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
Only make small amount of coffee spits and sputters hard to come out
You need to remove the salt build-up deposits. Run two cups of vinegar through your machine. (Add vinegar instead of water, no coffee or filter). Push start and let the vinegar fill the pot. When done, repeat if you think more scale/deposits will come out. Do a final rinse with water (plain water to rinse the vinegar). Then make coffee.
Sep 04, 2014 | Coffee Makers & Espresso Machines
My dough hook is stuck in my K mix kmx50.
yes the dough hook is a firm fit on those
Instruction Book KMX50, KMX59 English - Kenwood
www.kenwoodworld.com/.../Instruction-Manuals/kMix.../kMix.../18362iss2%20KMX..
Apr 29, 2017 | Kenwood Kmix Kmx50 Stand Mixer, White
Kmix mincer not rotating
Hi, it sounds like a broken gear.
Send me your email
Aug 12, 2013 | Kenwood Ax950 Attachment For Kmix Stand...
I have a Saeco Royal Coffee Bar that will intermittently fail to dispense espresso. It will grind the coffee but instead of dispensing the coffee, it dumps the (dry) coffee into the dreg drawer and resets...
Hi
Its not the water. More than likley its the lever on the right side of the machine at the top middle of the door. Its pushed all the way to the back or positive. Move it 1 mark towards the front of the machine and try again. If you put too much coffee in the brew unit, it can't compress it and kicks it out. It could also be your grind is too coarse. It should look like auto drip coffee.
Apr 02, 2011 | Saeco Royal Cappuccino Espresso Machine
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
Heating element issue?
Hi sounds like a thermastat problem control needs professional tech to look at it cheers john
Jan 18, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
718 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
