Question about Toshiba NB305N410BN Netbook
I dont know the bios pass key...Is there a default?
Mini nb305n410bl
    New Friend:
  • 7 Answers
Unfortunately this is a known issue with a series of faulty bios firmware versions that came out with a batvh of toshiba models over the last few years, your best bet is to try updating the BIOS (downloading the latest BIOS revision for your model here: www.helpit.net.au/Downloads/Toshiba/410BL_rev1.70BIOS.exe)
Run the update making sure to backup all your data BEFORE the update. this revision shuold remove the password bug from your system.
Regards,
David
Posted on Apr 29, 2013
HOW DO I GET PASSED A FORGOTTEN CURRENT PASSWORD
Is that a bios password or windows password ?
Mar 27, 2013 | HP Mini 1000 XP Notebook
When I turn on my Dell Inspiron 910 mini, it says tht media test failure, check cable. Operating system not found. Can somebody help me? I dnt know what to do
check the Boot order in the BIOS and make sure that is isn't set to Boot from LAN or Network first as the error "PXE *** Media Test Failure" ( where *** refers to the NIC card ID )
does in fact refer to a pc that is trying to Boot from the LAN or Network first.
If your boot order is set to boot from your Hard Drive first then I would suspect a bad Hard Drive.
Reboot your computer.
This is necessary, as entering the BIOS utility requires that you be outside of your normal operating system.
Press the key indicated during the startup messages to enter the BIOS.
This is traditionally either the "Esc / Delete" or of the "F2" key, but it can be anything, so pay attention to the screen as your computer loads up.
Navigate through the BIOS menu screens, using the arrow keys navigate to advanced bios features press enter to which device has been set to boot from.
using the arrow keys load failsafe defaults or load optimized defaults this will change the boot order press escape then press f10 to save to cmos to restart
hope this helps
Oct 02, 2012 | Dell Inspiron Mini 910 Laptop AC Adapter...
Cannt get past black screen on my hp mini 1151nr
IF YOU KNOW ABOUT COMPUTERS OPEN THE MINI, TAKE THE BOTOM 6 SCREWS OF THEN OPEN THE KEY BORD,UNDER THE MOUSE PAD IS THE BIOS BATTERY YOU HAVE TO GET TWO PIECES OF WIRE AND CROSS THEM SO THE SISTEM WILL RESSET TO DEFAULT AND THEN YOU CAN PROCEDE,
Apr 02, 2012 | Computers & Internet
DONT KNOW THE NETWORK KEY AND CANT GET ON THE NETWORK
You can use a pass-phrase scanner which will find and display the network pass-phrase and key. Or if its a small network then you can reset the router to factory defaults and use the default password to re-setup the network.. Sometimes its easier to reset to factory defaults but you have to have all your ducks in a row. You need to know the WAN details and any printer specifics and open port details etc.
..and you will have to setup every machine on the network to use the new passphrase/key. ..ooorrrr get a network scanner to reveal the pass phrase/key
Jan 18, 2011 | Computers & Internet
Im trying to set my computer back to the factory default settings, and i dont know the function keys. i need to do this because i want to start from scratch with out having to delete alot of stuff that i...
computers dont realy have a factory reset the only reset function that exist is with bios to do this when the unit is first turned on press f12 and it will take you into bios but if you dont know what your doing i would not mess with bios but its your computer
best luck
Oct 14, 2010 | Dell Latitude C610 Notebook
Hi i have a hp mini netbook and i change the password las night but i forgot the password and i dont know much about computer and i dont know what to do
*Is it a user account or Admin account. ?
*if it is a user account restart ur pc and press F8 key continuosly to get booting options
* select safe mode and hit enter.
* go to control panel and enter user acounts option. u can view the useraccounts profile, change the password there and restart ur computer.
* if it is a Admin account go to bios settings by pressing del key on reboot and change passowrd in the bios.
Aug 26, 2010 | Computers & Internet
When i start the through error overclocking failed! please enter setup to re configure your system how to solve this problem
If you dont know how to reset your bios settings back to default, maybe you should not be overclocking.
Enter your bios (check google for the key you need if you dont know it)
click default settings
Jul 25, 2010 | Computers & Internet
PCG-9G1L SONY
not too sure what you mean here.you can reset bios to default or can set bios to factory reset.to set default ...when you turn on pc ,message at bottom left hand screen indicates which key to press to enter setup(bios setup) note...its very brief;mines f 10 for instance.at startup press this key and select load default then select save settings and exit;then ur pc restarts with default settings.
To reset bios to factory requires disassembly.
you locate rtc and remove battery(looks like large watch battery)for 5 minutes then replace,reassemble and restart pc.you dont need to know what rtc means(real time clock)or what it looks like cos the battery is right next to it.
Mar 04, 2008 | Sony VAIO FXA63 Notebook
Bluetooth pass key
yes... the default is "0000". :)
- J.
Feb 21, 2008 | RIM BlackBerry 7290
Open Questions:
Toshiba NB305N410BN Netbook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
