Question about Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack
Autohelm faults The rudder reference bar has disappeared from the display in Standby. Have replaced the rudder reference unit but no change. The old reference unit has discontinuity so obviously faulty. The new unit has continuity but has made no difference. The helm works in Auto unless it needs large corrections then it seems to lose track of the rudder and starts to shunt.
4 Suggested Answers
  • 43 Answers
SOURCE: Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
Posted on Oct 13, 2009
SOURCE: Autopilot shows "no rudref"
how do connect my autopilot
Posted on Mar 17, 2010
  • 64 Answers
SOURCE: Trying to calibrate smartpilot, and controller
It sounds like the rudder feedback has a dead spot in the center of it. The replacement part numbers:
Rotary (inboard engines): M81105
Linear (outboard engines): M81188
Posted on Jun 14, 2010
Drive unit error navpilot 511
That errors means the autopilot is trying to move the rudder but it thinks its not moving. If you can manually move the rudder in standby mode with the green or red buttons on the 511, then the problem is typically with the rudder feedback unit. i.e. the rudder is moving but the only way the pilot knows it is if the signal changes from the rudder feedback unit.
If you can't make the pump work with the arrows (or anything else) then the problem lies with the pump. Check 12VDC to the pump and the connection to the processor.
Apr 03, 2014 | Boating
Rudder reference unit
Hi, the first thing I would do is check the wiring from the course computer to the feedback, on both ends and also check the rudder feedback mechanical link to the rudder.
It is possible that the problem is in the course computer but a problem with the feedback wiring or the feedback itself is much more likely. If the wiring looks ok and the mechanical connection looks ok, I would then check the feedback potentiometer to make sure it moves smoothly when the rudder moves. You can check it with an ohm meter. Depending on what it reads, you can then replaces the feedback or do further troubleshooting. The feedback is a just a 5k ohm potentiometer. Here are instruction on how to test a potentiometer.
95% of the time, problems like this are problems related to the feedback and not the course computer. I don't know if there is a reset for the computer, I would have to call the factory and ask, the manuals don't mention it. If it turns out that you do need a new feedback, I just so happen to have a new one in my shop.
Feb 18, 2012 | Boating
Motor only steers too one side. I have reversed the polarity and it still drives the same side.
what type of pilot?
Is there a rudder reference unit installed? if yes check rudder ref unit.
Does it does this only in auto?
Set standby and check if +10 and -10 pilot is turning in correct direction.If not See manual for installation drws and setup instructions.
Sep 18, 2010 | Raymarine St 4000 Wheel Drive E12093
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
My furuno autopilot 511 has a rudder reference unit which worked and then stopped displaying rudder position. I assumed it broke and replaced it. I still get no display. How can I clear the unit. I had a...
the rudder setup needs to be done. follow prompts, very common to be screwed up, read directions carefully and make sure that if it says steer hard starboard, it is hard starboard before you proceed! 847-746-0100
Jun 01, 2010 | Furuno NavPilot 511 GPS Receiver
Autohelm ST 6000
Check the installation manual for initial setup,if system worked before ,check rudder reference unit for broken wire loose connection or defective unit (it is a potentiometer resistance shoud change smoothly with position)
May 21, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Oct 03, 2009 | Raymarine Boating
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
AP35 Autopilot
Yep, if rudder calibration values are OK, then there is a real problem with calibration, it can be a mechanical problem or a faulty rudder feedback unit. Follow procedure at page 93 of user manual :
AP35 Autopilot Instruction Manualto troubleshoot the error, if you cannot get rid of the error message you may have to replace the rudder feedback unit or to have the unit inspected by a technician.
Aug 14, 2008 | Simrad AP35 GPS Receiver
Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack Logo
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
