Question about Raymarine Boating
ST6001 Rudder Bar
The rudder bar on my ST6001 has disappeared. Have replaced the rudder reference unit but no change.
2 Suggested Answers
  • 7 Answers
SOURCE: rudder reference unit
Hi, the first thing I would do is check the wiring from the course computer to the feedback, on both ends and also check the rudder feedback mechanical link to the rudder.
It is possible that the problem is in the course computer but a problem with the feedback wiring or the feedback itself is much more likely. If the wiring looks ok and the mechanical connection looks ok, I would then check the feedback potentiometer to make sure it moves smoothly when the rudder moves. You can check it with an ohm meter. Depending on what it reads, you can then replaces the feedback or do further troubleshooting. The feedback is a just a 5k ohm potentiometer. Here are instruction on how to test a potentiometer.
95% of the time, problems like this are problems related to the feedback and not the course computer. I don't know if there is a reset for the computer, I would have to call the factory and ask, the manuals don't mention it. If it turns out that you do need a new feedback, I just so happen to have a new one in my shop.
Posted on Feb 22, 2012
Testimonial: "Thank you John, I have fixed problem after viewing the page 151 of the manual you sent which gave me a hint that I fixed the reference in wrong position so that it produces opposite direction and travelled only short distance resulting to restricted angle of rudder even when actual rudder turned fully. Thank you again. "
Drive unit error navpilot 511
That errors means the autopilot is trying to move the rudder but it thinks its not moving. If you can manually move the rudder in standby mode with the green or red buttons on the 511, then the problem is typically with the rudder feedback unit. i.e. the rudder is moving but the only way the pilot knows it is if the signal changes from the rudder feedback unit.
If you can't make the pump work with the arrows (or anything else) then the problem lies with the pump. Check 12VDC to the pump and the connection to the processor.
Apr 03, 2014 | Boating
I AP 35 Setup
ensure you are setting correct rudder value.
Aug 14, 2008 | Simrad AP35 GPS Receiver
Turns hard to starboard when in auto
Verify that it is configured for your installation. Some units can be installed either on the port or starboard side, and they have to be programmed accordingly. Verify this in the user's manual.
Jul 04, 2013 | Raymarine St8002 Smartpilot Autopilot...
Rudder reference unit
Feb 18, 2012 | Boating
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
My furuno autopilot 511 has a rudder reference unit which worked and then stopped displaying rudder position. I assumed it broke and replaced it. I still get no display. How can I clear the unit. I had a...
the rudder setup needs to be done. follow prompts, very common to be screwed up, read directions carefully and make sure that if it says steer hard starboard, it is hard starboard before you proceed! 847-746-0100
Jun 01, 2010 | Furuno NavPilot 511 GPS Receiver
Autopilot shows "no rudref"
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
847-746-0100 www.technicalmarine.com
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
AP35 Autopilot
Yep, if rudder calibration values are OK, then there is a real problem with calibration, it can be a mechanical problem or a faulty rudder feedback unit. Follow procedure at page 93 of user manual :
AP35 Autopilot Instruction Manualto troubleshoot the error, if you cannot get rid of the error message you may have to replace the rudder feedback unit or to have the unit inspected by a technician.
Boating Logo
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
