My gestetner copy printer 5375 is showing error code e11 what is causing it
5 Suggested Answers
Metawatch
  • 96 Answers
SOURCE: gestetner printer error sc371
SC371 YellowiD Sensor Detection Error
Posted on Feb 09, 2008
rockfixya
  • 679 Answers
SOURCE: open heat error on gestetner
open the back cover and you find a two wire connector just near ribbon connector it is thermistor connector the printer is sensing this connector as open or not connected explore and fix.
Posted on Feb 09, 2009
  • 32 Answers
SOURCE: Gestetner 5308bt copy printer error after switching
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Posted on Dec 07, 2009
  • 903 Answers
SOURCE: gestetner dsc38 error code
sc386 is a color density error specific to black, but it usually is caused by the development unit rather than the drum. If the drum is old or worn you may want to replace it, but almost every time, replacing the DV unit will get rid of the sc386 error code.
Posted on Jul 29, 2010
Copyprinter 5375 why does one of my ink drums not work nto accept master
Consult Authorized Service Center or official Helpline of Manufacturer.
Apr 26, 2014 | Gestetner Office Equipment & Supplies
Gestetner 6123cp
i have gestetner copy printer model 6123 cenhelp me removed earror code e-00 please help me
Aug 17, 2013 | Office Equipment & Supplies
What causes error 12 on a gestetner 6123 duplicator
6123 gestetner digital copy printer no salve problum single line on copy. cleane complete scanner and thermalhead,
May 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
I have Gestetner DSM 730 and it give me an error of serial no: k8654300136, so the problem
how can I reset one copy Gestetner DSM 730 if screnn touch does not afiche we do not even know the code up above.
Feb 11, 2012 | Gestetner DSm730 Black and White Copier
Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
Feb 28, 2011 | Gestetner 2212 Digital Imaging System...
My gestetner 5430 is err cod E 16 can you solv it plis
get solution gestetner 5430 copy printer e-16 error code
May 22, 2010 | Gestetner Office Equipment & Supplies
Ricoh copier 3813 - error e
E codes are displayed in the copy counter.To display both digits of the E code press the enter key.
E11 exposure lamp error.Possible causes exposure lamp open thermofuse open.
E12 exposure lamp error Ac drive board defective or main board defective.
Oct 26, 2009 | Ricoh Aficio 450 Copier
REX ROTARY DSM618 D SC545 ERROR CODE
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
Jul 18, 2008 | Gestetner DSm515pfd Digital Copier -...
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
Gestetner dsc38 error code
You have an improper black toner density. Likely your black toner suction mechanism is clogged or the black toner supply clutch is not working.
Feb 21, 2008 | DSC GESTETNER - DSc38u Color Printer
k24674
jasbo
jasbo
