I have a 32" Emerson HDTV. I can't get some of the
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
It sounds that its main system control memory IC is damaged. Do a hard reset to this set, and try. Unplug the set from AC mains wall socket, and re-plug it back after 5 minutes or so. This must make it a hard reset. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Posted on Apr 29, 2013
  • 19 Answers
SOURCE: loses channels when shut off. must auto program
Your may be in shop mode, I'm not sure if Vizio's have a service menu. Go to setup and go through the install process again, watch for a demo or shop mode setting. If there isn't a setting then you need a new mainboard
Posted on Mar 22, 2009
dsacco86
  • 1077 Answers
SOURCE: it being emerson 32" hdtv lcd turns on but immediately turns off
This is Emerson's #1 problem.
The Inverter Transformer on the power supply/backlight inverter board goes bad. It's what powers up the screen for your TV. When the part goes bad, it doesn't have enough juice to power the screen and the TV automatically turns off. You have 5 Inverter Transformer on your board.
You can fix the problem by replacing the whole board or replace the bad Inverter Transformer.
Here's where you can get a new board for a good price:
http://www.shopjimmy.com/catalogsearch/result/?q=lc320em9+inverter
Or, here's where you can get replacement Inverter Transformers:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Posted on Jun 17, 2009
  • 603 Answers
SOURCE: Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
Posted on Jan 14, 2010
  • 8457 Answers
SOURCE: Need to program channels
This is a LCD tv right?U want to hook up free air or pay cable tv.Go in ur tv menu goto setup,go down to CH.press than pick AIR or CABLE.Than just pick one press scan u will get all free air channels or get all ur pay cable channels
Posted on May 26, 2010
SOURCE: My dynex 32'' HDTV keeps losing its channel labels
I have same problem...
Posted on Dec 21, 2010
I cant pick up any channels on my 32'' Emerson hdtv with my channell scan
Did you select antenna in the setup menu?
If you did and still can't receive anything you may not be receiving signals strong enough. Read the setup instructions in the manual. link below.
LC320EM9 EMERSON LCD TELEVISION Manual
Sep 09, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Emerson 32 HDTV LCD...my picture is smaller than the screen. How do I make the picture fit the screen. I'm missing a few inches of the images on both side...?
Most Emerson remote controls have a "FORMAT" button. Each button press cycles through TV Screen aspect ratio choices, such as Normal, Movie Expand, Wide, Zoom, etc. Pick one that fills your screen. You will probably have to change this setting again, depending on the signal source or channel selected.
The button cycles through the choices in a loop, so you can always get back to Normal.
Mar 24, 2013 | Televison & Video
Emerson TV black screen
If you have back light the problem is T-con board however if no back light the problem is inverter board
Jun 06, 2012 | Emerson LC320EM9 32 in. LCD HDTV
How to remove channels from my emerson tv
With the original remote in the main menu there should be a way to manually delete individual channels--no remote you are out of luck....
Emerson LC320EMX stays in standyby mode
one of the transformers has an issue which is very common for that model. You can get a replacement inverter from www.tvrepairworld.com
Mar 31, 2012 | Emerson LC320EMX 32 in. LCD HDTV
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv. I have to...
This is my second set in as much days from Best buy. Exact same problem.
Sep 21, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Horizontal "running" lines throughout the tv
You have a defective LCD panel. If it is under warranty, exchange it ASAP. If not, it's time for a new TV, as it is usually more expensive to repair it than buy a new one.
Jul 06, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
