Question about Trust TB-5300 Slimline Design
Driver Problems Whenever I install the 15356_03 drivers and restart my PC the mouse will not work, the cursor will just sit there and I can't move it. If I then uninstall the drivers and restart the mouse will work properly again. I can't use my tablet without the drivers but I can't use my mouse when I use them. Are there any solutions that you know of that might fix this problem please? Thanks.
My cursor on laptop wont move
ok then plug a usb mouse then restart the computer
got to the computer manufactures website and look for support to download the touchpad driver , install it, disconnect the usb mouse and restart the laptop i if it sttill doesnt work its probaly the touchpad that needs replaced.
Aug 01, 2014 | Computers & Internet
When I plug in an external mouse, it won't click.
If an external mouse does not work correctly, you may need to install device drivers for it. Windows does not support all 'mice' just by plugging them in. Download and install the drivers for the mouse from the manufacturers web site. Do NOT do a factory recovery for a device driver problem.
Jun 29, 2014 | Lenovo IdeaPad Yoga 13
When typing the cursor will move to a different place
For all Panasonic Toughbook Models this is a symptom when you do not have the correct "TouchPad" driver installed.
Please go to the following Panasonic Toughbook Driver Site:
http://pc-dl.panasonic.co.jp/dl/
Choose your Model (CF-30).
Choose your Operating System
Choose Keyboard, Mouse and Peripherals Drivers,
Download and Install the Drivers.
You will need to restart your computer.
That is it. The TouchPad will now properly work.
Good Luck and Best Regards from:
Richard, Montreal Based Panasonic Canada Authorized ToughBook Dealer since 1989.
Feb 04, 2014 | Panasonic Toughbook CF-30 Notebook
My acer 15.6inch the cursor is frozen wont move
Which mouse are you using? Is it the integrated mouse or the USB mouse?
If you are using the USB mouse, then try checking if it's plugged in correctly.
If it's your integrated mouse, then restart the computer and when it's up. Try moving your mouse. Restarting it usually does the trick.
If restarting it won't fix the problem, then restart and boot to safe mode. While restarting, tap F8 until you see the options to boot to safe mode. Highlight safe mode by using the arrow keys and hit enter. When you are in safe mode, try moving your mouse. Works or not - update the mouse driver. You can use RadarSync. If no go, then you might need to do a system restore. If worse comes worst, do a complete operating system reinstallation.
I hope this helps!
David
Mar 25, 2013 | Computers & Internet
Havimg problems with mouse not moving the cursor.
Check and make sure that the mouse is properly attach to your PC. the color of the mouse socket is green so better plug it to green ps2 port of the PC. Restart your PC, restarting your pc refreshes the driver of your mouse.
Mar 28, 2011 | Computers & Internet
Mouse cursor not working. cursor only moves with mouse plugged in and some of the keys do not work please help
try pressing FN+F5 or FN+F6 once. it might be disabled. if not try uninstalling the driver, restart the computer and let it install automatically.
Jun 10, 2010 | ASUS Eee 4G Notebook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
Sony vaio touch pad not working.
i have sony vaio vgn-sz58gn model laptop with windows xp installed. but on touchpad whenever i move cursor to up, it goes to down. if u move cursor to down, it goes up. can you provide me solution pls for that?
Awaiting
Apr 20, 2009 | Computers & Internet
Cursor not moving on screen
When you plug in the mouse you need windows to pop up and say found new hardware,and it will install a generic driver. I would shut down and restart and then plug it in again, if this does not work try installing the driver from disk that came with mouse, unplug mouse, install,plug it back in and try it.
Hope it works for you.
Mar 21, 2009 | Microsoft Wireless Optical Notebook Mouse...
Trust TB-5300 Slimline Design  Logo
44 people viewed this question
Top Trust Computers & Internet Experts
micky dee
Computer Links
Robin Hill
Robin Hill
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
