Question about Visioneer Xerox WorkCentre 3550 - Multifunction fax / copier / printer / scanner - B/W - laser - copying up to: 35 ppm - printing up to: 35 ppm
Xerox 3550 solve jam in exit area how can i solve
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
We had a paper jam in the print engine area. Once the paper path has been cleared we are still receiving clear misfed paper in print engine. I have fed paper through the path and cannot find any paper jam.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Area" you should check and possibly replace the fuser exit actuator (part# 120N00534). Iteminc.com has this part in stock and ships same day. Here is a video the shows you how to check and replace the fuser exit actuator. Good luck, and thanks for using FixYa!
Jun 17, 2011 | Xerox WorkCentre 4150 Black and White...
Paper jam in area before fuser
One possible solution, check on the left hand door when you open it. There is a spring loaded exit flag on the door, these can break causing jams at the fuser.
Dec 21, 2010 | Xerox Phaser 7750DN Laser Printer
Paper jam in a Xerox Comy Centre C20
A couple of things.
There is a bushing at the front of the exit transport that fall out of the frame. That requires removing the scanner and looking in the exit transport that way.
You may also have something stuck in that transport. Take the fuser back out and then take a minella folder and push it through from above the fuser to the output area and see if it disloges anything. If not, then you have to pull the scanner off and look in that exit transport area for problems.
Jun 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
What does code J1 mean on a xerox work center pro?
J1 mean any paper jam in paper feed area or sensor displace.lower cassate or multi pass tray.clear jam paper then solve your problem.
Dec 23, 2009 | Xerox WorkCentre M-24 Color Copier
When it jams it says 10-105 at the bottom left of
This problem is common when heavyweight paper is fed from the tray long edge first. and then the fuser exit sensor did not actuate within the specified time. Clean the drawer from dust or oil. if this not solve the problem change the fuser exit sensor
Oct 27, 2009 | Xerox DocuColor 12 Printer
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
Visioneer Xerox WorkCentre 3550 - Multifunction fax / copier / printer / scanner - B/W - laser - copying up to: 35 ppm - printing up to: 35 ppm Logo
62 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Computer Links
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
