Question about Facebook Apps
Help can't get pass level 135 help - Facebook Apps
    New Friend:
Blokiran sam odblokirajte mi poker
Posted on Apr 29, 2013
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
THERMOSTATE REPLACEMENT ON HOME HOTWATER CYLINDER
in big water heater therostat is at below/down side where the inlet/outlet connection are seen.before doing some thing plez drayn out the water of the heater than put the heater on the ground level carefully after that with the help of pliyer & keys open the screws after that u can see there is a heating element & a thermostat is present after that u can replace it.
Note:- If there is some mistak so, plez i'm sorry..................
Sep 04, 2012 | Water Heaters
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
I change spark plugs and wire because the car was idle was high. It was running fine before we change the plugs and wires just high idle. But now it run ruff, pops and back fires and you have to punch the...
sounds like you have the firing order off ! re- trace your wires from coil packs to plugs, you have one or several mixed up, the coil packs are numbered, and you wil have 135 on one bank and 246 on the other, If I'm not mistaken 135 are closest to the radiator, you can tell by seeing which head is the farthest forward towards pass side of car and that is Bank 1 which will have 135 cylinders.
May 28, 2012 | 1989 Buick LeSabre
Trouble code po400 and po410
Have a 2004 Chrysler Crossfire codes 412 403 135 155 154 134 want pass inspection cel stays on replaced secondary air pump same problem help !!
May 04, 2012 | 2004 Chrysler Crossfire
Me temp gage is passing the center line but my car does n't overheats
First I suggest to check coolant level; could be a wrong about engine coolant temperature sending unit go to bad.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 10, 2012 | 1997 Ford Expedition
I wanted to know the firing order for a 1993 Chevy s10 4.3 litre. And where no. 1 cylendar is located?
1-6-5-4-3-2 and 135 is on the driver side and 246 is on the pass so no 1 is the front cyl on the driver side hope that helps
Feb 02, 2011 | Chevrolet S 10 Cars & Trucks
What is the fireing order for a 1995 chevrolet camaro 3.4 liter v6?
123456. odd numbers on drivers side even on pass side 1 is driver front of engine 2 pass side front of engine.
in order front to back drivers 135 same for pass side 246 front to back.
May 03, 2009 | 1995 Chevrolet Camaro
Facebook Apps Logo
21 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
