Question about BenQ MP610 Multimedia Projector
Driver Shut off without giving cooling time, now not working
  • 25 Answers
That's a classic power supply failure. Usually, replacing the electrolytic capacitors in the power supply will be the remedy. Also, check for a blown fuse. Although, the fuse usually won't blow unless there is an internal problem.
Posted on May 01, 2013
1997 Honda cooling fan takes a long time to shut off after car is turned off
There is no fix. Small cars such as honda, Saturn, ect have computers that when it sinces the England is hot the fans will not shut off untill cool... even when the car is off :) enjoy it because without it our small aluminum engines will melt
Jul 04, 2014 | 1999 Jeep Grand Cherokee
My dell vostro 1015 gets completely shut down without giving any prior warning..i have to restart it again and it shows that windows didnot shut down properly.it happens 3 to 4 times a day.plz help..
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Dec 02, 2011 | Dell Vostro 1015 Laptop
LAST NIGHT I FORGOT TO SHUT THE DOOR AND THIS MORNING IT IS NOT COOLING,FREEZER OKAY(IT WAS CLOSED PROPERLY)
Give it time it will cool back down for you. Let me know if it will cool down .OK
Aug 09, 2011 | LG Refrigerators
Unexpected shut down of my HP Compaq I was trying to close the windows I was working witt when all of a sudden without notice my laptop shuts down. I tried to restart it but it would not. I took off the...
Compaq's are famous for over-heating, if you didn't have a cooling pad under the laptop it may have burned up some components, or it could just need time for the components to cool.
Jan 07, 2011 | Computers & Internet
AUXILARY WATER PUMP RUNS ALL OF THE TIME, I CAN REMOVE THE FUSE AFTER TURNING THE CAR OFF AND IT IS FINE UNTIL THE KEY IS TURNED AGAIN, THEN IT WON'T SHUT OFF UNTIL THE FUSE IS REMOVED. IS THE RELAY IN THE...
This is called an "After-Run" aux pump that is working normally. This prevents fluid residue build up through the cooling system while the engine is shut off. If you'll notice unlike the old style non aux pump system the coolant stays pink in color vs dark brown color with burnt odor. This helps circulate the fluid while the engine is cooling down. Without this the fluid gets cooked from the hot engine block because the fluid is not flowing (water pump shutdown). It will shut down after 10-15 minutes.
Feb 03, 2010 | 2003 Volkswagen Jetta TDI
My computer restarts alone ! on/off ?
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck
Dec 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
The pc turns off without warning
Sometimes when you add a new device to your computer, you computer will have a driver conflict and just reboot or shut off. If nothing was introduced to your computer here lateley then it may want to run Windows updates.
Another thing that may cause thing like this to occur is if your CPU fan is not functioning properly. The computer will automatically shut off because of overheating. If you can, unplug everything from your computer, open it and with a can of air, blow it clean and look at all the cooling fans.
Oct 09, 2009 | Computers & Internet
Cooling fans are running for a long time and still
If the fans are running long after the car is shut off, the fan relay is fused together. Unplug the cooling fan relay and get a new one. Don't drive it far without that relay though. Put it back in and drive to your supplier.
Aug 16, 2009 | 2002 Ford Windstar Cargo
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
Engine overheated, now car won't start without giving it gas
Some cars cut off as a fail safe to overheating especially on newer cars. The computer controls the fans and if they are not working the computer is probably telling the car to shut off. Have you replaced the motors already, if not, this is what's happening. Once you replace the motors it should run fine. I wouldn't suggest driving it too much with this problem as it may affect the computer by giving it false info.
Oct 21, 2008 | 2005 Dodge Magnum
BenQ MP610 Multimedia Projector Logo
65 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
