Question about LG Dryers
Water in Salt dispenser
The salt dispenser is filled with water.I've cleaned the filter inside the dishwasher, but I've heard there is another filter at the back that might be causing water to push into the salt dispenser if blocked.Any advise?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Salt dispenser?
Posted on Dec 19, 2013
5 Suggested Answers
JR JR
  • 116 Answers
SOURCE: Kenmore Oasis washer - water accumulates in bleach dispenser
somethinf clooging dispenser, remove water from dispenser and get small straw and un clogg,,,,,,,, thats it
Posted on Nov 30, 2008
kel1guy2002
  • 3740 Answers
SOURCE: where is the filter to clean so that water fills
Tun off the water to your washer and remove the hoses where they connect to your washer. Look inside of those connections and the water screens are inside the plastic fittings. Gently remove them and clean them on BOTH sides under running water. An old tooth brush works fine as does a few good snaps or thumps with the fingers. Hold them up to the light and make you can see light thru them. Once you finish... reinstall the screens then hook up the hoses and turn the water back on. Check your fill pressure on hot cold and warm..... You should see a noteable difference.
Posted on Jan 07, 2010
  • 2006 Answers
SOURCE: Hi tehre, everything seems to work -
Rost; I will take a WAG at it. Either your thermostat is not telling the heater element to turn on or the heater element is broken. The heating element is the more likely and can be tested with an ohm meter to make sure.
Posted on Jun 19, 2011
Salt holder full of water
Hi Elizabeth
have had a dishwasher for many years and have found this to be a normal practice .... Hope this puts your mind at rest ????
Mar 20, 2016 | Dishwashers
On start DW drains but does not fill...putting hot water into machine will get it to start and run cycle sometimes only...
Main control board is bad. Drain sequence is a power on test, Main board is not sending signal to open valve or is sensing water is present in the machine when it is not.
Feb 03, 2016 | Thermador DWHD651GFP Dishwasher
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 | Dishwashers
Hi, I have a BEKO GS5323 Dishwasher that has just
sounds like the sault filter has broken. it is in the base at the bottom its a thin plastic filter type. will need to be changed.
Sep 29, 2013 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
Bosch sgs45c02 salt container ful of water
the salt dispenser is always full of water, this is normal and you have no need to drain it. Just ensure you fill the dispenser with salt when the "Low Salt Light" is illuminated
Oct 03, 2012 | Bosch SGS45C02 Dishwasher
Bosch dishwasher SHX46AO7UC/14 Cycle doesn't run. I suspect the filters are clogged with our hard water. Have cleaned the main outlet to best of my ability but how do you get at inlet filters?
You will have to get to the back of the machine where the water feed pipe is.
There can be a filter at the supply tap and also in the back of machine where pipe goes into the unit.
If you have hard water do you use salt (dishwasher salt not cooking) in the water softener dispenser and adjusted the machine to the correct level ?
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Bosch Integra® 500 SHX46A0 Dishwasher
White film on glasses. Cannot find solution,
Check water quality. clean the drain filter in the machine. Check spray arm spray jet holes. Clean if clogged.
If you suspect salt chamber try removing all the salt by flushing with water externally. Refill with fresh salt.
Jul 08, 2010 | Servis 23 in. M4306 Free-standing...
Dryers Logo
201 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
