"I am trying to get wifi but I can't connect to wifi from my iPhone it doesn't let me"
YEP, i can solved this issue, try following steps..
1. connect your IPHONE to your pc/laptop(make sure you have latest itunes).
2. take backup from "your's iphone" right click and select backup
3. after completed go to summary in ituns.
4. select "restore iphone". and chose next if asked
5. after finished it select restore backup form itunes and
when it finished you done.
try it 100% working.... thnkyou
You can tell iPhone is connected to the Internet over a cellular data network if you see , or in the status bar at the top of the screen.
Do you have problems connecting to any other wireless network with your iPhone?
Have you tried using the forget this network option on your iPhone for your wireless network followed by trying to connect to the network again, and/or using the reset network settings option on your iPhone which erases all previously saved wi-fi connections that you have successfully connected to with your iPhone?
Let me know....
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: My Iphone 3G won't connect to home wifi.
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
SOURCE: mu samsung champ duos can
you need to go to network settings and change the method of connection there, after that you should turn off your wifi and this will ensure that you only use mobile internet
SOURCE: WIFI Connection Problem - connects only to EDGE
If you want to use wifi only when your at home you can go in and manually disable the cellular data so the internet will only be wifi based. Probably saving you MB's and data cost.
Go to Settings, General, Network, then simply turn off the Cellular Data. Then it won't connect anymore to the cell data and rely only on wifi when your connected to it.
And simple follow the same steps and revers the process when your out on the go.
Thanks
