Question about HP LaserJet M1005 Printer
Error scanner 20 - HP LaserJet M1005 Printer
    Problem Solver:
  • 4 Answers
I can solve your issue .give me your email on my ameetpatel007@yahoo.co.in id. i write you how to solve ...
Posted on Apr 29, 2013
Scanner error 20?
Here is a link to help with HP LaserJet Error Codes.
Go through them, follow the procedures and you may find this useful and helpful.
http://printertechs.com/tech/error-codes/error-codes-index.php
Also, this link below, however, explains what Error 20 is and how to fix it in a "little" more detail.
--Printer Not Activated - Error 20--
I hope these help you.Regards, Mike
Mar 24, 2015 | HP LaserJet M1005 Printer
HP Laserjet M 1005 Scanner error 20 solution.
Hp are tricky scanners to install and setup. You need to unplug the USB cable, power on the scanner and begin a fresh setup.
Let the software tell you when to reconnect the USB cable to the computer. Let it finish setup and reboot computer. Once in windows, the setup will complete automatically.
Go in START menu and click on the HP Solution Center in the HP folder to activate the scanner.You can't jsut press the SCAN button on the scanner. It won't work. You need to start the software first or use Photoshop.
Also, the way to fix this Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. You should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
Make sure you have enough HD space to install as this can contribute to the same error 20 code.
Dec 12, 2014 | HP Office Equipment & Supplies
Scanner error 20
upper scanner gear or motor fault, or may be scanner cable fault. so check it.
Apr 18, 2014 | HP LaserJet M1120 MFP All-In-One Printer
I have error 50.22.00 in my Hp M602 printer
Error: 52.XX.00 Error To continue turn off then on
Error Description: Laser/scanner error ? XX = 00 laser/scanner motor startup error ? XX = 20 Laser/scanner rotation error
check your printer scanner assy. need technician support.
Oct 08, 2013 | HP LaserJet 600 M602DN Laser Printer - M
Hp 1005 Scanner error 20 please suggest the problem
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it. Plug the device directly into the wall socket.
Use thepower switch to turn the device on.
Jul 08, 2011 | HP LaserJet M1005 Printer
HOW TO SET HP LASERJET 1005 PRINTER SCANER ERROR 12
how to solve engine scanner error for hp laserjet p1005
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
HP LJ M1120 SCANNER ERROR 20 HOW CAN I SLVE THIS PROBLEM
According to HP Tech manual, it says...
20 Error/Memory overflow: Applies to all Laserjet printers
Add more internal printer memory or too much data or data too complex, simplify the print job and retry.
Apr 29, 2010 | HP LaserJet M1120 MFP All-In-One Printer
SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 20
your scanunit's lamps frecuenci is changed you should replace the scanunit
Jun 20, 2009 | HP LaserJet M1005 All-In-One Printer
TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Select your operating system and download the driver "TWAIN Driver - LiDE 20 Scanner Driver Ver. 7.0.3.1a_xp" and then download the software "Canoscan toolbox" ...here is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6624
Aug 04, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
HP LaserJet M1005 Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
