Question about Pride Mobility Products Jazzy 1170 XL Plus
My jazzy 1170xl plus won't move. When I power it on the lights come on like there supposed to but as soon as I move the joystick the battery level lights start to flash rapidly. 9 of the 10 lights flash. What does this mean and what can I do to fix it?
    Sergeant:
  • 317 Answers
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
Posted on Jun 06, 2013
dromtonpa
  • 40 Answers
SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Posted on Mar 30, 2009
  • 175 Answers
SOURCE: have jazzy select series need to know flashing Code #9
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
Posted on Jul 09, 2009
  • 29 Answers
SOURCE: jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
Posted on Sep 07, 2009
  • 27 Answers
SOURCE: flashing lights and chair does't run
Sounds like it's locked. Try this: Controller Locking Instructions
Posted on Oct 15, 2010
  • 132 Answers
SOURCE: my jazzy select 14 on
well a wrench means the obvious that something needs adjusting , if it came with an instruction manual search for the code 9 blinks will mean.
Posted on Oct 16, 2010
Jazzy stopped one day. Plugged in charger and it will still not move. Replaced batteries and it will move a couple feet then stop.
shouldnt even move with charger plugged in sounds like a controller problem or joystick have a tech fro dealer check the error log they can tell u what is wrong from that
Oct 11, 2013 | Pride Mobility Products Jazzy 1170 XL Plus
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Why are the lights blinking and it won't go
read manual,lights flash when in security mode,everyt model has a unlock procedure with the buttons on the joystick control.
Jan 23, 2013 | Pride Mobility Jazzy 1143 Power Chair -...
CHAIR IS CHARGED UP BUT WILL NOT MOVE
ajnss I need more information. can you turn the power on at the joystick? are you getting all the lights for battery level lit? are any of the lights blinking on the joystick? do you hear a clicking noise when you try to move the chair? Give me as much info as you can thanks
Feb 05, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Lights on joy stick controller blink on and off and chair wont move
Cezna Are the lights that are blimking the battery level lights or they the speed level lights. If it is the speed level lights then the chair thinks you still have the charger plugged in. If it is the battery level lights do a certain number of lights flash 3 lights flashing 4 lights flashes etc this is the flash code and will tell you what problem you have. It could also mean that you are in lockout or sleep mode If you have the VSI joystick then turn on the power immediately push the joystick forward and hold until you hear a beep then mmediately push it to the rear til you hear a beep then immediately let it return to the center position. If it was in sleep mode this should wake it up. Hope this helps you
Sep 13, 2010 | Pride Jazzy 1650 Heavy Duty Power...
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
Problem with joystick on Jazzy 1103 ultra
You will need to take it in for repair. 8 bar flash usually means you have a bad joystick/controller. They can sometimes send it in to the manufacturer to have it repaired. Find a reputable dealer and relay this info to them.
Apr 01, 2009 | Pride Jazzy 1103 Ultra Indoor Power...
Pride Mobility Products Jazzy 1170 XL Plus Logo
235 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
