Bosch WAE24460AU are they brushless
Drum wont spin
5 Suggested Answers
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
dnewcombe1
  • 1564 Answers
SOURCE: bosch classixx 1200 wont spin or drain
There are two drive belts, I'm sure one is gone.
Posted on Jun 20, 2009
SOURCE: bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
Posted on Jul 23, 2009
ZJLimited
  • 17970 Answers
SOURCE: I Need user manual for Bosch Maxx Lifestyle
I suggest visit this link for Bosch WAE24460AU User Manuals.
Hope this helps (remember to rating this free answer).
Posted on Oct 07, 2011
Code 08 on bosch wfk 2401
Faulty door switch
Aug 27, 2014 | Bosch WFK 2401
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
I Need user manual for Bosch Maxx Lifestyle WAE24460AU
Sep 28, 2011 | Bosch Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Bosch WFMC3200
Click on Bosch (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Plug off the wall, open up behind, you will see things.
Pl rate if helped.........
Jan 02, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch wont spin
go back inside it and look at the place where the drive connects to the drum is there anything loose or missing that should be attached the drive coupling breaks or comes loose, i dont know about this particular model if its a belt driven or what but look closely at the connection to the drum and see if anything is abviously loose or broken.
Dec 20, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Wont spin, and arcs.
2 bruhes in motor
replace motor brushes
use correct brushes from bosch
Oct 09, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
