Question about Camping, Backpacking & Hiking
ExtendedColeman Trecking Pole beyond stop
Extended the trecking pole beyond stop. Cannot click back into original position. The spring is showing
  • 2976 Answers
SOURCE: How do I put together the pole caddy (4 shelf) with spring?
Put the poles together eith the spring section on the top. Otherwise, the weight of what you put on it will pull it down.
Posted on Feb 05, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Looking for 2 15amp single pole pushmatic circuit breakers.
A Google search for "15 amp pushmatic" turned up several links. Here's one for a retailer with new ones and an eBay store with cheaper prices (maybe pullouts):
http://www.aplussupply.com/break/push/push.htm
http://stores.ebay.com/Sparkys-Place_Pushmatic-Categories_W0QQfsubZ10975954
Did you also check the big-box stores like Home Depot or Lowe's or electric suppliers in your area?
Posted on Feb 11, 2009
  • 4088 Answers
SOURCE: mcculough MCP1510 chainsaw pole broke
Looks like you will have to make one to fit if no replacement is available.
Posted on Jul 08, 2009
dontbother10
  • 2220 Answers
SOURCE: I broke the plastic clamp lever for the extendable pole
pn 121560-01 is the lever. Type it into the "Part #:" window and the answer is NLA at
Remington.com
http://www.desaparts.com/index.htm
Do an internet search for Remington 121560-01
M & D Mower say they have one $37.50
http://www.m-and-d.com/order.html?id=R3XMdxQn
I wouldn't waste any time. Good Luck
Lou
Posted on Nov 06, 2009
Testimonial: "Thank you, it was very helpful."
SOURCE: My shower pole caddy is either too tall using the
I had the same problem. The only solution is to cut the shorter rod to the desired size. After I cut it, it fits perfectly over the bathtub. Hope this helps!
Posted on Sep 20, 2010
Antishock open too far
The answer is actually very simple but not immediately obvious. no doubt the spring is showing and there seems no way to push the pole back in. there is a collar above the spring on the top part of the pole all you have to do is slide the collar down the pole over the spring, then retract the pole and slide the collar back up the pole to its original position.
Mar 30, 2014 | Hama Alpenpod Walking Stick / Monopod For...
Coleman trecking pole
That is not a car or truck.
Apr 29, 2013 | Cars & Trucks
I extended the pole too far. Though I follow the instructions about reducing the length, I cannot get the pole to readjust. Please help.
Unscrew the bottom pole (with the basket) where the spring meets the upper, wider pole but not all the way and then retighten. It should allow you to compress it back in. Worked for me.
Mar 02, 2013 | BAFX Products Camping, Backpacking &...
Purpose of the pole switch
The right hand drive have the bumper poles in front of the left hand head light. when the switch is pressed to the on position, the pole extends like an antenna and it has a green light on top of it. It helps to light up the area so you wont hit the curb and scrape the rims." __________________
Oct 08, 2012 | Toyota Cars & Trucks
What's the extended grip for?
The extended grip allows a lower grip position. The low grip is useful on steep traverses so you won't have to shorten the length of your pole.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
I have stripped the thread in an extendable tent pole.
if you go to any good tool store or engineering store you can get what is known as helecoil insert.just tell them the inside diam of the pole.they will probably put it in for you if yuo take the pole along.hope this will help.regards barry.
Sep 17, 2009 | Sport & Outdoor - Others
I have the model 108526-01 Remington pole saw which has the round pole with a plastic compression nut (which recently broke). Can I buy the newer octagonal pole and if so, does it use the same saw mounting...
I have the sollution, had the same problem with the broken compression nut. Just use two hose clamps, one to hold the pole extended and the other clamps around compression base. Its a cheap easy fix and it work great fo me. The Real Mr.Fixit
Apr 03, 2009 | Remington Electric Pole Saw
The pole is stuck won't detach from the head of the vaccum, and the pole won't extend anymore
please say which type of vac? assume upright ? with a flx hose and attachments for vac of stairs or hard access areas are u saying the flex hose with the pole iside it stows at rear of vac and unclips extends pole from flex hose?? which part is stuck ?
Oct 19, 2008 | Panasonic Vacuums
Camping, Backpacking & Hiking Logo
326 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
