Question about Liebherr Premium CTP 3153 Top Freezer Refrigerator
Freezer is cold but ice is melting and totally not making ice
Freezer makes ice cubes but ice cream Melts.
ice is made at 30 degrees ice cream is not hard till about 3 degrees.
freezer not cold enough.
Jan 24, 2017 | Refrigerators
My daughter left door open on Meila freezer and ice is now refrozen and clogged. What should I do?
By far the safest and easiest is to remove product and switch off freezer leave door open and totally defrost the freezer - allow a day or so to make sure all ice has melted - clean cabinet and return cabinet to service
Mar 10, 2015 | Refrigerators
Freezer does not seem to be cold enough, seemed like it took forever to make ice trays and ice cream is really soft and bread not totally frozen...
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 29, 2011 | Frigidaire 20.6 cu. ft. Top Freezer...
I have an LG LFC21770 refrigerator and have noticed a build up of ice on the back wall of the freezer section. Yesterday, when I opened it to get some ice - the ice was frozen but had obviously melted...
If the freezer fails to defrost you get ice building up at the back of the freezer.
The defrost cycle relies in a thermistor transducer to detect the ice build up and to turn on the defrost cycle. The water usually then drips down to a tray under te fridge and then gets evaporated away.
Hopefully you only have a problem with the thermistor and not the defrost circuitry,
This is hard for a repair man to diagnose as when you call them out to your fridge it will be impossible to diagnose if the freezer is totally packed with ice.
And if you let it defrost totally it will be hard to diagnose as they may not be allowed to use freon to cool the transducer.'
So if you call someone in to check this you need to know if the ice build up will be a problem for them .
Youtube has several videos on this situation .
Apr 21, 2017 | LG LFC21760 Bottom Freezer French Door...
Cannot adjust refrigerator temp (warm) and freezer will not produce ice
There is an ice dam in the freezer port which is preventing cold air from passing into the refrigerator. Remove the bottom panel and melt the ice. Make sure the passageway in the very back of the freezer is completely clear of ice.
Oct 03, 2009 | Kenmore Refrigerators
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Freezer has stopped freezing
SOUNDS LIKE YOU HAVE A DEFROST ISSUE. THERE ARE SEVERAL THINGS YOU WILL NEED TO TEST TO CONFIRM WHICH PARTS ARE BAD, BUT YOU CAN GET YOURSELF GOING AGAIN TEMPORARILY BY REMOVING THE BACK PANEL FROM THE FREEZER, THERE YOU WILL FIND THE EVAPORATOR AND IF IT IS ICED UP YOU CAN THAW IT OUT BY USING HOT WATER OR LEAVE THE DOOR OPEN UNTIL THE ICE MELTS. MAKE SURE TO UNPLUG UNIT BEFORE DOING ANYTHING. AFTER ALL ICE IS MELTED COVER BACK UP AND THAT WILL GET YOU COLD AGAIN FOR A FEW DAYS MAYBE WEEKS. LET ME KNOW IF YOU NEED HELP WITH THE COMPONENT TESTING.
Jan 27, 2009 | Refrigerators
Ice on the bottom of freezer
Sounds like your freezer drain is blocked. first, turn the temperature controller up a little bit, maybe one or two stops, then wait 24 hours to see if the ice melts at all. If it starts to go away, then you may need to toss a few towels on the floor next to the freezer because 6 inches of ice melt is gonna make a mess.
After you get that sorted out, turn the temp down one click to make sure that everything is staying cold, and that the ice is not reforming.
good Luck!
Jan 25, 2009 | Frigidaire FRS23KF7AB Side by Side...
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Liebherr Premium CTP 3153 Top Freezer Refrigerator Logo
14 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
