Question about Nokia 6230
Half of the keypad is dead
Some of the keypad are not functioning the problem started just like that.
0 characters
1 Points
N73 function keypad dead
My Dear Brother Your Phone Keypad Ic Default So please change Keypad ic and Keypad problem will solved
Dec 19, 2012 | Nokia N73 Cellular Phone
Number pad buttons dead
keypad contact, open the phone then clean the contacts using a regular pensil eraser, on the keypad, try to brush out the dust using a toothbrush or a small PC vacum cleaner
good luck
Jul 28, 2008 | Samsung T509 Cellular Phone
6210 keyped slution
If half of your keypad is not functional then it must b a hardware problem!
goto a mechanic
Dec 11, 2011 | Nokia 6210 Navigator Cell Phone
Keypad light not functioning
Dec 05, 2010 | Nokia e65 Cellular Phone
Motorola karma. Only the red key works, none of the others is recognized. Took battery out, no help
Hi, most problem caused by keypad not functioning, is always water issues.
Unscrew the phone and clean up the keypad area. And your done.
After cleaning up the keypad,if it does not work, means that the problem is from the board of the phone.
There is an IC inside the phone that controls keypad function, when IC gets damaged, keypads will not function until it's replace.You will need to contact a skillfully personnel for help.
Oct 09, 2010 | Motorola Mobility Karma QA1 Cell Phone
The keypad function not respond when i push it, so i can't unlock the keypad, what can i do with my nokia 6120c?
Hi, what causes the keypad not to function is that, the keypad might be dirty or the keypad IC that controls the function of the keypad might be damaged.
You can unscrew the phone and clean up the keypad area and see if it will function.If it doesn't function,that means the keypad IC inside the phone is damaged and will need replacement.
Have a nice day.
Sep 13, 2010 | Nokia 6120 classic Cellular Phone
I have an older model motorola razr that the screen went blank but it is stil working.
Yes this is the most common problem with the RAZR.
There is a small cable connecting the screen to the keypad part of the phone. This cable is called a flex cable and fits through the hinge of your RAZR so that the screen and keypad are connected even as the phone opens and closes on the hinge.
BUT, this cable often wears out or can even be severed even a slight bit, and the phone would then work, but only the bottom half, the screen would be dead. I fix this issue for people more than any other cell problem. You need to have the flex cable replaced.
Nov 28, 2009 | Motorola Mobility RAZR V3
Cell phone problem as below
the cable may need to be replaced or have the keyboard service.
Jan 24, 2008 | Motorola Mobility A630
Outer keypad of motorola A630 does not function properly.
take the phone and have the keyboard (Outer) replaced or service.
Motorola Razr Keypad
It is a humidity issue. I had the same problem with my phone. I baked it in the oven on the lowest setting for 20-30 minutes and it works fine now :)
Sep 06, 2007 | Cell Phones
Nokia 6230 Logo
19 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
