Question about Kyocera Mita FS-C5016N Printer
Yellow line on edge of page
I have a Kyocera Ecosys FS-C5016N Printer. When it prints it has prints a yellow line abour 1-2mm along left edge of page. Also have dots of ink/toner on page and generally prints an untidy copy because of these marks. does this happen with other printers? Any ideas folks??
  • Anonymous Mar 13, 2014
    a straight line is visible every time I print or copy. how to remove?
  • 36 Answers
Clean the LED array for the yellow unit. Clean the corona and grid.
Or you might have a bad segment on the LED array.
Posted on Oct 25, 2007
On a ricoh - that would be the pcm - photoconductor module on an ecosys the module should last 100,000 pages nothing ever seems to last that long send an email to http://www.pcandl.com/ or call where you bought it
Posted on Aug 07, 2007
SOURCE:
How do I print double sided with this copier
pick print on both sides (flip long edge or flip short edge) in the print driver. go to kyocera support to download latest kx driver if the options are not found in your current driver
Apr 04, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
When I print in black form a Kyocera Mita FS-C5016N printer the ink looks smduge. Do you have any suggestions/solutions for this?
It could be a fuser, drum, developer, or transport belt problem among other things. The FS-C5016N is an old model color printer and if the maintenance kit has not been replaced it probably should be. THe maintenance kit contains the items above along with a few others.
Aug 17, 2010 | Kyocera Mita FS-C5016N Printer
Copy Count
hit the menu key....scroll down untill you see print status page..hit enter twice
Jan 22, 2010 | Kyocera Mita FS-C5016N Printer
Kyocera mita fc c5016n printer
go into your print driver properties and set it to spool...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Nov 20, 2009 | Kyocera Mita FS-C5016N Printer
How do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Nov 19, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
FS-c5016 dumping toner yellow blue?
vacuum out yellow and cyan developers... if problem persists most likely have to replace developers
Nov 11, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera FS-c5030N printing pages yellow
Push in the charge corona assy. Its behind the left door. Each color has a cleaning rod and charge assy. I've seen this more than once.
Aug 27, 2009 | Kyocera FS-C5030N Led Printer
Printing all pages as black
Open up the left side door and push in all of the chargers to make sure they are seated.
Jan 17, 2009 | Kyocera FS-C5015N Laser Printer
Kyocera FS-C5016N
when you open the left cover you will see some green plastic things. If you pull these towards the left they will clean print heads and charge coronas.
If this does not fix the problem the you will have to remove the dev and drum units from the machine.
The print head sits on top of the drum unit and can be levered off with the three tabs gently lifted.
the entire print head can be remove once the black cover has been unhitched from the sides.
The print heads are not screwed in and what ever you do DO NOT TOUCH THE SCREWS on the print heads as they are only for density adjustment
Aug 08, 2008 | Kyocera Mita FS-C5016N Printer
Kyocera Mita FS-C5016N Printer Logo
479 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
