Question about Boating
Outboard carburetor carburetor vent blocked
  • 56 Answers
1987 25h p Johnson starts but dies after 30 to 45 seconds. Carb not blocked
Is the gas tank vent open? I had the same problem with my outboard and the vent was plugged up.
Sep 05, 2017 | Garden
How to Clean an Outboard Carburetor?
didnt specify unit --generic answer --best way is to buy a rebuild kit [should have instructions]--carb cleaner --disconnect carb --and tear down the carb becareful their are small parts inside using cleaner cleal all parts and housing --in the rebuild kit should be instructions on putting it back together
15 minute Carburetor Cleaning Rebuild Yamaha 20HP outboard 4 stroke How to Clean an Outboard Carburetor Outboard Motor Carburetor Cleaning
Oct 20, 2016 | Boating
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Apr 13, 2016 | Motorcycles
1993 Johnson outboard while running good will go from full throttle to barely running sometimes 5500 to 2500rpm. Carburetors rebuild gas lines good and good spark.
If your boat has a inboard tank check the Anti Siphon valve. Try to run the outboard on a separate fuel tank to isolate the fuel source to see if it is the boat or the engine. A clogged vent line will also do that.
Mar 30, 2016 | Boating
Why my 2006 tohatsu 5 h.p outboard will not idle down to trolling speed without spitting sputtering then dieing.
Remove the carburetor and thoroughly clean all of passages by compressed air you probably have blocked passage for fuel on the low idle side
Nov 09, 2014 | Seloc Mercury Outboard Engine Repair...
Yamaha outboard troubleshooting
can you check that the fuel tank breather is not blocked.
Jul 17, 2017 | Boating
Carburator on a Mercury 9.8 outboard motor loosing prime
Your question doesn't make sense,If primer bulb is going flat you have a blockage between primer and tank.also check fuel vent on tank is open
Mar 31, 2014 | Seloc Mercury Outboard Engine Repair...
Outboard 4 cycle rpm flucuating
It could be many issues with fluctuating,
1 -gas pump in suffices supply
2 - spark plugs / wires
3 - Air intake clogged
4 - Carburetor need overhaul cleaning
5 - check for the smoke color could be piston oil ring warned out.
6 - head block cracked.
7 - Compression test to all 4 cylinders.
Jun 24, 2013 | Light Outboard Motor Boat Bass Fishing...
I need a carb diagram for yamaha tzr 250 cc motor cycle year 1988 it will not rev with out choke on . blocked jets?
Hi, Rolandwhitfo and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
TZR 250 WON START
Will start but wont stay running without choke Yamaha Outboard Parts Forum
Yamaha TZR250 1987 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tz-owners-manuals
Aug 08, 2011 | 1988 Yamaha TZR 250
93" 115 H V4 Johnson outboard motor will start and idle fine
your carburetors might be dirty blocking flow to the high speed jets causing it to bog down
Jun 29, 2010 | RTO Outboard Motor Bass Fishing Boat Rod...
Boating Logo
49 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
