Question about Car Audio & Video
Glove compartment repair
Can't open to remove disks
  • 4 Answers
SOURCE: my 94 850 sedan's glove compartment will not open.
turn the handle and push down on the glove compartment. it will unlock and open up if you apply enough pressure
Posted on Mar 27, 2009
JShreader
  • 50 Answers
SOURCE: remove glove comartment
Hello mrock107, my name is JShreader. Thank you for choosing fixya.com.
First, remove the Glove Box and Glove Box Frame. Then release the wire harness from the clamps on the evaporator. Remove the filter lid, then pull out the A/C filter assembly from the evaporator housing. I uploaded a picture for you in .pdf format showing you how to get it out. You can download it by clicking HERE. I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader!
Posted on Apr 01, 2009
rockitman187
  • 2559 Answers
SOURCE: cannot open glove compartment handle broke
If you raise the handle and look under it,you will see a metal loop sticking out,If you grab that with a pair of needle nose pliers Or other small pointed object and pull,It will open.
Posted on May 19, 2009
SOURCE: Glove Compartment Box Won't Close
Check out this link. Explanation for the fix. http://forums.vwvortex.com/zerothread?id=2359362
Posted on Sep 07, 2009
SOURCE: Glove compartment stuck
I just opened my friend's stuck Toyota Corolla glove compartment by
pushing in on the bottom right front with my foot while pulling the latch and giggling it. The latch turned out to be broken. Good luck.
Posted on Sep 10, 2009
How can i remove my 2005 honda element glove box , it won't open at all
Remove side clips holding the glove compartment into the console and unhook the elastic string that guides the compartment. -------------------------------------------------------------------------------
Super VAG K+CAN V4.8
Apr 03, 2013 | 2005 Honda Element
How do i remove the glove box in a saturn ion?
Here are instructions on how to remove a glove box on a Honda Accord: 1. Remove these items: Dashboard center lower cover and Passenger's dashboard lower cover. 2. Remove the screws from bottom of the glove box. 3. Wrap a flat-tip screwdriver with protective tape, and apply protective tape around the related parts, to prevent damage. Insert a flat-tip screwdriver in the notch of the cap, and release the hooks by prying up the cap. 4. Remove the screws. 5. Release the hooks, then pull down on the-------------------------------------------------------------------------------------
VVDI VAG Vehicle Diagnostic
Mar 23, 2013 | Cars & Trucks
Need a digram of taking a dashboard out of a 2005 impala
  • Turn the engine of the Impala off and open its hood. Use a socket wrench to remove the negative cable from the battery.
  • Remove the four screws securing the driver's side kick panel, using a Phillips screwdriver. Use a slotted screwdriver to pry out the kick panel. Remove the passenger's side kick panel the same way.
  • Remove the metal plate from the driver's side of the vehicle under the Steering wheel by detaching its two securing bolts with a socket wrench. Pull the plate off to reveal three electrical connections. Unplug the three connections.
Glove Compartment
  • 4 Open the glove compartment and empty its contents.
  • 5 Remove the two screws at the back of the glove compartment.
  • 6 Pull the glove compartment off of the dashboard.
Center Dash Panel
  • 7 Remove the two screws securing the radio and the two screws securing the A/C unit with a Phillips screwdriver.
  • 8 Remove the four corner screws of the center dash panel faceplate with a Phillips screwdriver. Pull the faceplate off.
  • 9 Use a slotted screwdriver to pull the radio and A/C unit toward you.
  • 10 Reach behind the two devices and disconnect their connections. Pull them out of the vehicle.
Dashboard
  • 11 Remove the two screws underneath the steering wheel, using a Phillips screwdriver.
  • 12 Remove the two screws on the lower right side of the dashboard, using a Phillips screwdriver.
  • 13 Remove the 10 mm bolt from both side panels with a socket wrench.
  • 14 Remove the defroster grille by pulling it out. Remove the four screws along the top of the dash near the windshield.
  • 15 Pull the dashboard off the Impala and detach the two electrical connections. Lift up the dashboard and remove it from the vehicle.
Sep 22, 2012 | 2000 Buick LeSabre
How do I change the cabin air filter on my 2002 Toyota Avalon XLS ?
The cabin air filter is actually pretty easy to change. Here are the steps:
  1. Set the air conditioning system to Recirculation. The case for the cabin air cannot be removed with the system in the Outside Air mode.
  2. Turn the engine off.
  3. Open the Glove Compartment
  4. unclip the damper rod on the ride side of the glove compartment. To unclip it usually it is just a squeeze tab but sometimes it is a phillips head screwdriver.
  5. The glove compartment now must be squeezed together at the rear to allow the tabs to be released. Just let the glove compartment hang down.
  6. Through the glove compartment opening, locate the filter cover and remove.
  7. Remove dirty filter and replace with the new and reverse steps 1-5 to put it back together.
Shouldnt take to long usually takes me about 5 minutes to change it.
Apr 15, 2010 | 2002 Toyota Avalon
Directions on replacing a cabin air filter for a 2004 Avalon
Mar 16, 2010 | 2004 Toyota Avalon
Electrical problem under dash How do I remove dash?
Instrument panel upper trim panel
Instrument panel
  1. Disconnect the negative battery cable.
  2. Disable the Supplemental Inflatable Restraint (SIR) system.
  3. Carefully pry upward, using a small, flat-bladed tool, to remove the defroster grille.
  4. Remove the Sunload and Headlamp Auto Control sensors from the defroster grille.
  5. Working through the defroster grille opening, remove 3 upper trim panel retaining screws.
  6. Remove the heater/air conditioning vents from the front of the instrument panel by releasing the tab on each side from inside the vent and pulling out.
  7. Working through the vent openings, remove 4 upper trim panel retaining screws and remove the upper trim panel.
  8. Remove the instrument cluster.
  9. Remove the right and left A/C vent trim panels.
  10. Open the trap door in the rear of the glove compartment and remove the passenger inflatable restraint wiring connector from the retaining clip on the rear of the glove compartment assembly.
  11. Remove the 4 glove compartment-to-instrument panel retaining screws.
  12. Pull the glove compartment assembly outward enough to access the wiring connectors for the glove compartment switches. Label and detach the wiring connectors.
  13. Remove the glove compartment assembly from the instrument panel.
  14. Remove the retaining screws and courtesy lamps from the right and left sound insulators and remove the sound insulators.
  15. Remove the steering column opening filler trim by grasping at the front and rear edges and pulling downward.
  16. Remove the 4 retaining bolts and the steering column opening bracket.
  17. If equipped with full console, remove the console.
  18. If equipped with mini console, remove the radio.
  19. Remove the headlamp switch module.
  20. Remove the 2 bolts and the hood latch release.
  21. Move the driver's seat to its full rearward position.
  22. Remove the steering column.
  23. Remove the 8 instrument panel retaining screws, detach the wiring connector at each side of the instrument panel, and remove the shims at the lower mounting screws.
  24. Remove the instrument panel with the aid of an assistant.
To install:
  1. With the aid of an assistant, position the instrument panel in the vehicle.
  2. Attach the wiring connector at each side of the instrument panel, install the shims and the 8 instrument panel retaining screws.
  3. Install the steering column.
  4. Install the hood latch release with the 2 bolts.
  5. Install the headlamp switch module.
  6. If equipped with mini console, install the radio.
  7. If equipped, install the console.
  8. Install the steering column opening bracket and the steering column opening filler trim.
  9. Install the right and left sound insulators.
  10. Position the glove compartment assembly and attach the wiring connectors to the switches.
  11. Push the glove compartment into place and install the retaining screws.
  12. Place the passenger inflatable restraint wiring connector on the retaining clip on the rear of the glove compartment assembly and close the trap door.
  13. Install the right and left A/C vent trim panels.
  14. Install the instrument cluster.
  15. Position the upper trim panel on top of the instrument panel, making sure the sensors are through the trim panel.
  16. Install the upper trim panel retaining screws through the heater/air conditioning vent openings.
  17. Gently push the heater/air conditioning vents into place.
  18. Install the upper trim panel retaining screws through the defroster grille opening.
  19. Install the Sunload and Headlamp Auto Control sensors to the defroster grille.
  20. Gently push the defroster grille into place.
  21. Enable the SIR system.
  22. Connect the negative battery cable.
Dec 01, 2009 | 1995 Cadillac DeVille
Pleaase advise how to install the Cabin Filter on a Hyundai 2003
Open glove compartment. Press inward at both sides of the glove compartment, then lower the glove compartment.Remove the lower side instrument panel and crash trim pad. Remove the four glove compartment upper cover retaining screws, then the cover. Remove the two glove compartment retaining bolts, then the glove compartment. Press on the cabin air filter cover tab, then remove the cove
Remove the cabin air filter from the blower unit opening. Install a new cabin filter, ensuring the air flow marking is facing in the proper direction. Install the cabin air filter cover, ensuring the cover is properly installed.
Position the glove compartment to the instrument panel, then install the two retaining bolts. Install the glove compartment upper cover. Install the lower side instrument panel crash pad. Lift the glove compartment into position. Close the glove compartment.
Oct 30, 2009 | Hyundai Motor 2003 Sonata
Air filter replacement
Per Hondacarforum.com
"look for your air filter box. its a big square box on the right hand side of the car under the hood. you cant miss it. ther should either be clips or screws holding the box together. you have to get the top off of it to get to the filter... just replace the filter, and put the top back on and ur good"
per Chinogang Senior Member
May 06, 2009 | 2004 Honda Civic
Where is the cabin filter on 2001 hyundai accent locate?
Hi, this cabin filter is not the air filter, this is the A/C filter located behind the glovebox, remove a couple of screws and a bigger nutt, and the filter is located in a vertical box.
Feb 23, 2009 | 2001 Hyundai Accent
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
