Question about Refrigerators
"FR-480" & "fridge light not working" - Refrigerators
  • Anthony Rooney May 29, 2013
    I already replaced the buld with a new working one as I stated in the problem description
    What do you do if the light stops and it is not a problem with the bulb?
    Top Expert:
  • Refrigerators Master
  • 50,084 Answers
Remove the plastic cover after turning off power to fridge. the bulb will be a screw in type and may be simply loose in the socket. If not remove the bulb . Replace the cover and get a new bulb turn the machine back on until you do Any electrical wholesaler will have one Take the bulb as a sample.
Posted on Apr 29, 2013
Testimonial: "Did not read properly the problem description."
I was given an ilive dvd player boom box, model IBPD882B and the display screen doesn't work. Can I get another screen for player?
yes, but check connections
7inch TFT LCD Display HSD070I651 480×234 Resolution 7"Analog ...
https://www.ebay.com > ... > LEDs, LCDs & Display Modules > LCD Display Modules
7" HSD070I651 480X234 LCD Screen Signal Interface 26 pins TFT Specific Analog RGB, FPC. Resolution 480 ( RGB)×234. Viewing Angle 60/60/40/60 (Typ.). (CR?10) [Left / Right / Up / Down]. Display Mode TN, Normally White, Transmissive. ' eBay!
7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button ...
https://www.amazon.co.uk/234-Resolution-Button-Monitor-420-TV.../B013FVEJP2 7 Inch TFT LCD Color 480 x 234 Resolution Stand/Mount Rear Button Leg Monitor with 420 TV Lines Night Vision Camera: Amazon.co.uk: Car & Motorbike.
7-inch TFT LCD Module with 480 x 234 (RGB) Resolution, Available in ...
www.globalsources.com > All Categories > Electronic Components Number of the colors: 65KModule dimensions: 164.9 x 100.0 x 5.5mmVA size: 7 inchesAA size: 154.08 x 86.58mmResolution: 480 x 234 (RGB)LCD type: TFT and transmissiveViewing direction: 12:00IC: HX8227-A01 and HX8655-ABacklight: CCFL backlightOperating temperature: -10 to 60 degrees CStorage temperature: ...
Feb 06, 2018 | iLive Televison & Video
Ammeter wiring how do I wire -20/+20 12v gauge to 4 batteries wired in parallel in my caravan ? I have 480w of solar power, 4x120 a/h deep cycle batteries.I run 12v fridge, 12v TV plus lights,pumps,...
4 batteries in parallel equal 480 a/h so if you pull 10 amps as an example it would last 48 hours. To measure current the amp meter would have to be in series with the total output of the four batteries. If you go between the batteries current is divided due to being in parallel Divide the total a/h by the current being drawn to work out the time frame .
Jan 16, 2018 | Kitchen Appliances - Others
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
Fridge is beepng and now defrosting
TRY CHANGING THERMOSTAT... HOPE IT WORKS ITS RIGHT HAND SIDE OF FRIDGE BY LIGHT.
Feb 25, 2011 | Daewoo FR-147RV
I lost manual book for my fridge,(daewoo) How can
Go to this site and after open the page, click on down "Download Page"
http://www.pdf-manual.com/user-guide-instruction-owner-manual-daewoo-fr-094r%28ss%29-23349.html
Hope, you got it.
Jan 23, 2011 | Daewoo FR-094R Refrigerator With Ice Box
Help needed to clean the filter of fridge
You need to clean your coils - that is why your refrigerator is not cooling as well as it used to and will also solve the clean light. Whether they are underneath unit by taking off the kick plate or behind it is the same problem.
This should be done every 6 months (or more if dusty enviroment) to keep the problem was reoccuring. The brush accessory tool of a vacuum works best usually.
May 05, 2009 | Daewoo Refrigerators
Clarion vrx 485 vd.tuner works with amp but cant get dvd or cd to play with amp.screen works cd an dvd are playing but no sound.an with key off tuners playing till i open door?what have i hooked up wrong?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Mar 29, 2009 | Clarion VRX485VD Car DVD Player
Some times water flowing from bottom side of the fridge
There should be a drain pan directly below the icebox which needs to be emptied from time to time. Some units have a drainpipe connected at the back, if yours has one, it may have become blocked.
Mar 13, 2009 | Daewoo FR-064R Refrigerator With Ice Box
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
http://www.the12volt.com/installbay/stereodetail/1981.html
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Jan 01, 2009 | Car Audio & Video
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
