An example of a secondary memory would be? - Computers & Internet
    Brigadier General:
  • 3,400 Answers
I have a new heater with diferant terminals from the old one so not sure how to atach the wires
There is no need to rewire the internal of the heater!
Just bring in the electrical supply to the heater, it can be either 120 or 240 volts.
If the heater you have is like the picture associated with your post, then all then have to do is change the supplied plug from 240 to 120. It comes pre set for 240. That plug is inside the cabinet.
If any other brand, then you need to change the wires at the transformer of the heater. All heaters need to be supplied with primary voltage: 120 or 240. Then the control system is supplied with secondary voltage out of the transformer. The secondary voltage is no more than 28 volts. and these wires are normally colored as blue or yellow.
Secondary power is already wired within the heater. NO need to change where they are. You will only need to deal with the Primary wiring.
There are many varieties of transformers that transform high primary voltage to a low secondary voltage of 28 volts. and these transformers have many wires: primary & secondary.
I will try to make this easy to understand.
If you have a Gas Heater Transformer with these colors:
  • Red
  • Black
  • White
  • Green
Or...
  • Red
  • White with Red Stripe
  • Black
  • White with Black Stripe
  • Green
These are Dual Voltage Transformers, you can bring in either 120 Volts or 240 Volts
If you bring in only 120 Volts...
1st example:
The Red wire will not be used! Hot wire to the Black, and the Neutral/Common, to the white wire. Green to ground.
2nd example:
Connect the Red wire with the White with Red Stripe together and connect these to the incoming Neutral/Common wire, normally White.
Connect the Black Wire with the White with Black Stripe to your incoming Hot Wire, which is normally Black.
Green to ground
If you bring in 240 Volts...
1st example.
1 Hot wire to the Red, the Other Hot wire to the Black, and White wire is not used. Green to ground
2nd Example:
Wire nut the two Striped wires together. then one incoming Hot wire to the Black, the other incoming Hot wire to Red.
Green to ground
Or This is only a Low voltage - 120 Volts Only
  • Black
  • White
  • Green
Or either any of these combinations...
  • 2 Blacks w/Green
  • 2 Reds w/Green
  • 1 Black, 1 Red w/green
This type will only be a high voltage, 240 volts only
Picture below is what a transformer looks like and it is where your incoming supply wires go. The smaller leads with the spade connections will go to a specific location & is the 'Secondary" .
Good Luck
Mar 14, 2015 | Pool & Spa
ANn example of secondary memory would be?
A memory card. Most digital cameras accept a memory card of some type to expand memory.
Apr 29, 2013 | Cameras
Main Circuit Board b 2.40 gigahertz Intel Pentium 4 8 kilobyte primary memory cache 512 kilobyte secondary memory cache Not hyper-threaded Board: AOpen 1294 918AE10001 Serial Number: 30400590LM71 BIOS:...
attage ,
follow the mother board thorroly .try to look where the audo chip fited .write the name of the chip company.such as AD or REALTECK or ESS .It generraly fit top left corner of mother board .Write the company .and down load driver for audio.
look a m boad picture hare audio chip is realteck
so you should download the realteck driver
hope it wll solve your problem
if it solve you please vote for me
shibuda
Nov 24, 2010 | AOpen (918EA10I6D) Motherboard
Diff b\w primary device & secondry device memory device
primary is temporary memory... example RAM...
Secondary is permanent memory... example HDD,CD,Pendrive, flash drives etc...
Aug 05, 2010 | Computers & Internet
I bought a 2gig kit of memory from Dell for a precision 450 and it's only seeing 1gb in the Bios. Upgraded the Bios and it's still only seeing 1gb
You memory slots have primary and secondary slots. Switch the old memory with the new one and put the 1Gb in the secondary slot.
Sep 23, 2009 | Dell Precision 450 PC Desktop
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
Secondary camera and memory
erase messages? no in camera mode go to options and press the camera image then it will change so u can take photos with the "little camera"
Apr 19, 2009 | LG KU990 Viewty
How do i use ubuntu fixing ntfs file system?
Use apt-get from the terminal to install the ntfsprogs package - sudo apt-get install ntfsprogs
Then you can use the tool ntfsfix from the terminal to attempt to repair a ntfs partition.
Example:
* unmount the drive if it's mounted already
sudo umount /dev/sda1 - read below for device naming info
then type: sudo ntfsfix /dev/sda1
Note:
A typical home pc or laptop has 2 or 4 IDE channels as follows:
  • ide0 = primary
  • ide1 = secondary
  • ide2 = tertiary
  • ide3 = quaternary
For example:
  • ide0 = primary master = hda
  • ide1 = primary slave = hdb
  • ide2 = secondary master = hdc
  • ide3 = secondary slave = hdd
  • sata0 = 1st sata device = sda
  • sata1 = 2nd sata device = sdb
and so on...
SCSI & SATA devices are listed as devices sda, sdb, sdc, sdd, sde, sdf, etc. in the /dev directory. Similarly, partitions on these disks can range from 1 to 16 and are also in the /dev directory.
Now each hard drive has 4 primary partitions (limit of PC x86 architecture). First partition is denoted by number 1. For example:
  • First partition : /dev/hda1
  • Second partition : /dev/hda2
  • Third partition : /dev/hda3
  • Fourth partition : /dev/hda4
  • sata0 device, 1st partition: /dev/sda1
  • sata1 device, 1st partition: /dev/sdb1
And so on.
You can run command fdisk -l (lowercase L) to display a list of partitions:
WARNING! These examples may result in data loss. Use fdisk command with caution as it can manipulate / overwrite your partition table.
Aug 05, 2008 | Canonical Ltd. Ubuntu
Vw passat 2000 1.8t front wheel drive
please rate me solved...thanks
DTC P0411/16795: SECONDARY AIR SYSTEM - INCORRECT FLOW DETECTED
Test Requirements
Ensure all fuses are okay, battery voltage is at least 11.5 volts, all electrical accessories are off, A/C is off.
Ensure engine is mechanically sound.
Test Procedure
NOTE
Secondary air system is activated by ECM and blows air into exhaust pipe
upstream of catalytic converter for 100 seconds during a cold start, 41-91°F (5-
33°C). Engine must be cold to perform following test procedure.
1. Ensure fuse and secondary fuse (secondary fuse is 40 amp and is located in fuse holder on top of battery)
are okay. Check hoses and components of Secondary Air Injection System, for damage, loose fit and
improper installation, check vacuum hoses for Secondary Air Injection System. Repair as necessary.
Erase DTC memory. Verify repair. If DTC does not reset, test is complete. Perform ECM relearn
procedure. See TEST DRIVE RELEARN PROCEDURE .
2. Remove engine cover. Disconnect pressure hose from Secondary Air Pump Motor (V101), by pressing
buttons on hose connector. See Fig. 33 . Using scan tool, check Secondary Air Pump Motor (V101) in
scan tool Output Diagnostic Test Mode (Secondary Air Pump Relay activation mode). See OUTPUT
DIAGNOSTIC TEST MODE .
3. Secondary Air Pump Motor (V101) should run in intervals and air should exit pump at hose connection.
If Secondary Air Pump Motor (V101) is okay, go to step 7 . If motor runs and no air exits secondary air
pump motor, replace faulty Secondary Air Pump Motor (V101). Erase DTC memory. Verify repair. Test
is complete. Perform ECM relearn procedure. See TEST DRIVE RELEARN PROCEDURE . If
secondary air pump motor does not run, go to next step.
4. Disconnect Secondary Air Pump Motor (V101) harness connector, install LED test light at secondary air
pump harness connector terminals. Turn ignition on. Using scan tool, activate Secondary Air Pump Motor
(V101) in scan tool Output Diagnostic Test Mode (Secondary Air Pump Relay activation mode). See
OUTPUT DIAGNOSTIC TEST MODE . LED test light at Secondary Air Pump Motor (V101) harness
connector should flash. If LED test light at Secondary Air Pump Motor (V101) harness connector does
not flash, go to next step. If LED test light at Secondary Air Pump Motor (V101) harness connector
flashes, replace faulty Secondary Air Pump Motor (V101). Erase DTC memory. Verify repair. Test is
5. Using DVOM check resistance of Secondary Air Pump Motor (V101) wiring. See appropriate WIRING
DIAGRAM under ENGINE PERFORMANCE in SYSTEM WIRING DIAGRAMS. Resistance should
be a maximum of 1.5 ohms for each reading. Check wiring for short circuit to one another in Secondary
Air Pump Motor (N101) harness connector. Repair as necessary. Erase DTC memory. Verify repair. Test
Secondary Air Pump Motor (N101) wiring is okay, go to next step.
6. Check Secondary Air Pump Relay (J299) and Secondary Air Pump Relay (J299) wiring. See DTC
P0418/16802: SECONDARY AIR PUMP RELAY (J299), MALFUNCTION . Repair or replace as
necessary. Erase DTC memory. Verify repair. Test is complete. Perform ECM relearn procedure. See
7. Disconnect vacuum hose from Secondary Air Injection Valve (N112) and disconnect pressure hose from
secondary air pump motor, press buttons on pressure hose connector to disconnect pressure hose. See Fig.
34 . Blow lightly into disconnected pressure hose, Combi-Valve should be closed. Connect hand vacuum
pump to disconnected vacuum hose and apply vacuum to Combi-Valve, Combi-Valve should open. If
Combi-Valve opens when vacuum is applied, Combi-Valve is okay. Go to next step. If Combi-Valve
does not open when vacuum is applied, replace faulty Combi-Valve. Erase DTC memory. Verify repair.
Test is complete. Perform ECM relearn procedure. See TEST DRIVE RELEARN PROCEDURE .
8. Check Secondary Air Injection Valve (N112). See DTC P0412/16796: SECONDARY AIR
INJECTION VALVE (N112), ELECTRICAL CIRCUIT MALFUNCTION . Repair as necessary.
NOTE: Do not use compressed air to check Combi-Valve.
2000 Volkswagen Passat GLS
2000 ENGINE PERFORMANCE Self-Diagnostics - 1.8L Turbo
Jun 21, 2008 | 2000 Volkswagen Passat 4Motion
Computers & Internet Logo
David Payne
David Payne
