Question about Cameras
ANn example of secondary memory would be? - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
A memory card. Most digital cameras accept a memory card of some type to expand memory.
Posted on Apr 29, 2013
My watch has lost the tritium plug at zero on the bezel. how can i get a replacement? thank you
This is a dialog I had with a dealer:
Ann: How can I help?
you: I was wondering where would one go for watch parts for the sw tritium watches?
Ann: Smith & Wesson watches, Correct
you: yes
Ann: Here is the contact information for them
Ann: SMITH & WESSON
Ann: CAMPCO
Ann: 4625 W. JEFFERSON Blvd.
Ann: LOS ANGELES, CA 90016
Ann: www.smith-wesson.com
Ann: 888.922.6726
you: thank you
good luck and don't forget to vote!!!
Sep 28, 2010 | Smith & Wesson H3 Tritium Watch Yellow
Diff b\w primary device & secondry device memory device
primary is temporary memory... example RAM...
Secondary is permanent memory... example HDD,CD,Pendrive, flash drives etc...
Aug 05, 2010 | Computers & Internet
My name is not the owner of the wii fit. example, create new mii. the wii board says, "hi are you a friend of Ann". How do I change the name Ann to Jane
Turn on the Wii fit game.bypass all the stuff until the game is ready to start.Select Ann.Above her will appear an edit/delete something like that.Clicking on that will allow you to delete Ann.Then just creat a new Mii at the plaza.Good luck and game on!
Jul 07, 2010 | Nintendo Wii Fit for Wii
I bought a 2gig kit of memory from Dell for a precision 450 and it's only seeing 1gb in the Bios. Upgraded the Bios and it's still only seeing 1gb
You memory slots have primary and secondary slots. Switch the old memory with the new one and put the 1Gb in the secondary slot.
Sep 23, 2009 | Dell Precision 450 PC Desktop
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
Internal memory full - how do I find it? Ann
If you do not have a memory card inserted, the camera defaults to the internal memory, both in shooting and playback modes. You can transfer from internal to a card using the "copy" function from the playback menu. The internal memory can be erased from the playback menu using the format function in the "setup" menu. Don't erase (format) until you are sure the images are stored safely elsewhere.
Jul 02, 2009 | Fuji FinePix S1000FD Digital Camera
Vw passat 2000 1.8t front wheel drive
please rate me solved...thanks
DTC P0411/16795: SECONDARY AIR SYSTEM - INCORRECT FLOW DETECTED
Test Requirements
Ensure all fuses are okay, battery voltage is at least 11.5 volts, all electrical accessories are off, A/C is off.
Ensure engine is mechanically sound.
Test Procedure
NOTE
Secondary air system is activated by ECM and blows air into exhaust pipe
upstream of catalytic converter for 100 seconds during a cold start, 41-91°F (5-
33°C). Engine must be cold to perform following test procedure.
1. Ensure fuse and secondary fuse (secondary fuse is 40 amp and is located in fuse holder on top of battery)
are okay. Check hoses and components of Secondary Air Injection System, for damage, loose fit and
improper installation, check vacuum hoses for Secondary Air Injection System. Repair as necessary.
Erase DTC memory. Verify repair. If DTC does not reset, test is complete. Perform ECM relearn
procedure. See TEST DRIVE RELEARN PROCEDURE .
2. Remove engine cover. Disconnect pressure hose from Secondary Air Pump Motor (V101), by pressing
buttons on hose connector. See Fig. 33 . Using scan tool, check Secondary Air Pump Motor (V101) in
scan tool Output Diagnostic Test Mode (Secondary Air Pump Relay activation mode). See OUTPUT
DIAGNOSTIC TEST MODE .
3. Secondary Air Pump Motor (V101) should run in intervals and air should exit pump at hose connection.
If Secondary Air Pump Motor (V101) is okay, go to step 7 . If motor runs and no air exits secondary air
pump motor, replace faulty Secondary Air Pump Motor (V101). Erase DTC memory. Verify repair. Test
is complete. Perform ECM relearn procedure. See TEST DRIVE RELEARN PROCEDURE . If
secondary air pump motor does not run, go to next step.
4. Disconnect Secondary Air Pump Motor (V101) harness connector, install LED test light at secondary air
pump harness connector terminals. Turn ignition on. Using scan tool, activate Secondary Air Pump Motor
(V101) in scan tool Output Diagnostic Test Mode (Secondary Air Pump Relay activation mode). See
OUTPUT DIAGNOSTIC TEST MODE . LED test light at Secondary Air Pump Motor (V101) harness
connector should flash. If LED test light at Secondary Air Pump Motor (V101) harness connector does
not flash, go to next step. If LED test light at Secondary Air Pump Motor (V101) harness connector
flashes, replace faulty Secondary Air Pump Motor (V101). Erase DTC memory. Verify repair. Test is
5. Using DVOM check resistance of Secondary Air Pump Motor (V101) wiring. See appropriate WIRING
DIAGRAM under ENGINE PERFORMANCE in SYSTEM WIRING DIAGRAMS. Resistance should
be a maximum of 1.5 ohms for each reading. Check wiring for short circuit to one another in Secondary
Air Pump Motor (N101) harness connector. Repair as necessary. Erase DTC memory. Verify repair. Test
Secondary Air Pump Motor (N101) wiring is okay, go to next step.
6. Check Secondary Air Pump Relay (J299) and Secondary Air Pump Relay (J299) wiring. See DTC
P0418/16802: SECONDARY AIR PUMP RELAY (J299), MALFUNCTION . Repair or replace as
necessary. Erase DTC memory. Verify repair. Test is complete. Perform ECM relearn procedure. See
7. Disconnect vacuum hose from Secondary Air Injection Valve (N112) and disconnect pressure hose from
secondary air pump motor, press buttons on pressure hose connector to disconnect pressure hose. See Fig.
34 . Blow lightly into disconnected pressure hose, Combi-Valve should be closed. Connect hand vacuum
pump to disconnected vacuum hose and apply vacuum to Combi-Valve, Combi-Valve should open. If
Combi-Valve opens when vacuum is applied, Combi-Valve is okay. Go to next step. If Combi-Valve
does not open when vacuum is applied, replace faulty Combi-Valve. Erase DTC memory. Verify repair.
Test is complete. Perform ECM relearn procedure. See TEST DRIVE RELEARN PROCEDURE .
8. Check Secondary Air Injection Valve (N112). See DTC P0412/16796: SECONDARY AIR
INJECTION VALVE (N112), ELECTRICAL CIRCUIT MALFUNCTION . Repair as necessary.
NOTE: Do not use compressed air to check Combi-Valve.
2000 Volkswagen Passat GLS
2000 ENGINE PERFORMANCE Self-Diagnostics - 1.8L Turbo
Jun 21, 2008 | 2000 Volkswagen Passat 4Motion
HELP SYSTEM ERROR
Hi Ann, have you tried turning it on with the memory card out? Is there any other code appart from the "SYSTEM ERROR"? for ex - 0e01 ?
Jun 24, 2006 | Casio Exilim EX-S3 Digital Camera
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
