Question about Building Materials
If my front door is hollow, will it allow more cold air inside?
    Champion:
    New Friend:
  • 217 Answers
Probably, but it is also a security risk. All exterior doors should be made of solid wood, fiberglass, or metal.
Posted on Apr 29, 2013
What is a blend door on my jeep cherakee sport
this is a small door to control the hot air coming from the heather core to inside room on every vehicle including yours if this part is broken you could get no hot air from your heather or if this part is stuck open you get hot air all the time even with the heather off
Nov 15, 2014 | Cars & Trucks
Frigidaire mod.#affu2067ew2. Gasket snug and clean. Exterior door is very cold alot of condensate. Gasket is dry but door is wet.
sounds most likely didn't get a good fill in the foaming machine the fills the door cavities wiht insulation. I've been in a refigerator plant and seen it happen. They are supposed to be checked. Tap various places around the outside of the door to see if there is a hollow sound. It could just be around the outside edges of the door unless the whole door is cold.
Nov 18, 2013 | Frigidaire Freezers
02 navigator front heater blows cold air
Sounds like the blend door or blend motor is not functioning/opening. This door allows the heat/cold air to come in by adjusting open, closed or anywhere in-between for temp. Start there. They are usually vacuum controlled and mounted under the front dashboard near the knee board.
Nov 09, 2011 | 2002 Lincoln Navigator
What is the temperature suppose to be inside fridge?
fridge is supposed to be around 36-38 degrees freezer 0 to 10 depending on if your fridge area is not cold enough the freezer is the only side that actually gets cold and there is a fan located above the evaporator that pushes to cold air through a small door that opens and closes depending on how cold your unit is. If the unit gets to cold the door shuts not allowing any cold air to come into the fridgerator side. If you have any further questions message me back. Please also remember to rank how this opinion has helped in your appliance situation when our chat has fully completed it allows me to continue helping others in similar situations in the future Thanks Rick
Jun 11, 2011 | Whirlpool Refrigerators
Clicking sound, allows only cold air
You most likely need whats called a blend door actuator. It is an little electric motor that moves the blend door inside the heater box to allow either hot or cold air. The little plastic gears strip out and the motor cant move the door, hence the cold air and clicking noise.
Dec 08, 2010 | Mercury Mountaineer Cars & Trucks
Have a 1998 dodge caravan blows cold only new thermastst flushed system new anti freeze help
Most likely the problem is a broken blend door inside the heater box or a broken adjuster cable going to the blend door, the blend door inside the heater box is responsible for heater output depending on your temp adjustment on your heater control panel, most likely the blend door is stuck in the cold position allowing cold air to come through the vents verses allowing the blower motor to blow warm air past the hot heater core to produce heat, check the temperature adjuster cable behind your heater controls and make sure its connected and not broken, lastly make sure the blend door isnt broken and operating freely.
Dec 06, 2010 | 2000 Dodge Caravan
Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Sep 03, 2009 | 2002 Dodge Durango
A/c front blower is warm, but rear blowers are fine
This is a common problem and the solution usually is that the fron thermostat is usually gone and needs replaising. Shouldn't be too much money to get done. It's just not opening up to let the cold air pass into the from area but the rear one is working fine which allows it to blow cold air.
Aug 16, 2009 | 2006 Dodge Durango
A/c problem
You either have a bad control, or motor running the air direction door in the front HVAC unit, or a door that is stuck.
The front and rear units are totally separate.
The door directs where the air, cold or hot, should come out, whether it is panel vents, floor, defrost, or any combination of those.
This door and motor are located inside the heater box which usually requires a lot of the vehicle dash assembly to be taken apart to get to these parts.
Aug 28, 2008 | 2000 Ford Expedition
Icemaker
You might have a frozen line. Also and this seems more important to you its prob to cold, Trust me to cold of a refrig will cause hollow ice cubes first leading to a frozen line. Clean your coils, if you have another refrig empty out into that, unplug it leave doors open a couple days. If you can get to water line use a hair dryer from a distance defrost line, turn down freezer half knotch 1 full one at maximum. should fix issues, especially if filter already changed. If this all check prob a clogged line, not just frozen.
Mar 15, 2008 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Building Materials Logo
251 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
