Question about Home
What is the scale used in terrestrial globes?
    Problem Solver:
  • 22 Answers
A typical scale used for a terrestrial globe is approx. 1:40 million.
Posted on Apr 29, 2013
How does one start a payment gateway?
The global shift of business' focus to web markets has caused a consequential large-scale shift of payment modes. Today, it's possible to host a business in one corner of the globe and manage customers residing on the other side of the globe. However, every internet-based enterprise requires a reliable payment gateway to manage both online and offline payment processes including invoice generation, sending the invoice to customers and payment collection as well as payment reporting.
If you own an enterprise that intends to expand its market coverage to denser, far-flung locations or online markets, you will require a credible payment gateway to handle your payment collection process.
While the easiest and cheapest approach would be to seek the services of a white label payment gateway provider, this leaves you very limited room for customization as you are bound by their terms of service and features. The best approach is designing a personalized payment gateway.
May 12, 2017 | Computers & Internet
What is the correct way to use the viewfinder?
It is normal for everything to look inverted in an astro telescope. If you was to use it to view terrestrial, you will need to fit an erect image diagonal between the focuser tube and the eyepiece, such as
http://www.optcorp.com/os-d125ei45-45-erect-image-diagonal-1-25inch.html
This can still be used at night. The same is true for the small finder scope fitted to many telescopes. You can get a terrestrial type which can also still be used for planets etc
http://www.optcorp.com/tpo-8x50-right-angle-finderscope-and-bracket.html
Oct 10, 2015 | Optics
I just acquired a Toshiba 32HL95 TV and cannot get any hd channels although I have a digital cable box. I have tried using the coaxial, hdmi and video connections to no avail.
Try configuring your antenna input. Menu, Installation, Terrestrial, Input Config select your antenna 1 or 2 and > arrow over to select cable. Next auto program: under Terrestrial, Channel Program...this take some time.
Oct 23, 2011 | Toshiba 32HL95 32 in. LCD TV/HD Combo
CAN YOU PLEASE TELL ME WHAT IS ITS LENS SIZE,AND ALSO CAN I PURCHASE AN ERECTING EYEPIECE SO THAT I CAN USE THE TELESCOPE FOR TERRESTRIAL VEIWING
The eyepiece size (diameter) is the standard 1.25 in.
Erecting eyepiece adapters can be used with this scope.
maximum magnification is 250x therefore highest eyepiece would be 3.6mm
most useful magnification of any scope is 150x (900/150= 6mm eyepiece
Eyepieces provided with scope (Huygens type) have a narrow field of view and are relatively poor for astronomy but should be fine for terrestrial viewing
Mar 11, 2011 | Tasco Luminova 40114675 (675 x 114mm)...
CAble seems faulty-Is it a magnetic pick up? how can I test it?
The best and safest way (if you don't have a multimeter) is to use a torch battery, 3 pieces of wire and a torch globe. Attach wires to the centre terminal of the globe, & one to the globe base. Now cut the wire attached to the globe base and insert the torch battery between the cut ends.This creates a test circuit with the torch globe, & battery in series.There are now two wire ends free. To test your circuit, touch the two free wire end together. If you have done this right. the torch globe will light. To use your tester, touch one wire end to a pin on your shaver wall plug, touch the other wire to a hole in the shave end of shaver cable.If the globe does not light, try the other hole. If it still doesn't light, touch your tester wires together to test it's still working ok. Test the cable again, if no light, you have a broken power cable.
NOTES:
1. For this operation the razor and cable are NOT CONNECTED to the power outlet
2. Use insulated wire and solder them to the torch globe if you can, otherwise use a cheap globe holder from Tandy
May 01, 2010 | Braun 4775 Electric Shaver
Globe does not float.
take away the globe from the top magnet, then use your two hands to hold the globe, gradually close to the top magnet, pls note the floating distance is about 2cm, when you feel the balance, release your hands gently, finally, you succeed in floating it well. Congratulations!
Apr 24, 2010 | Globe Stellanova Series Magnetic...
Digital Converter Box
Hi William
You TV is able to receive Free to air Terrestrial Analog broadcasts by just connecting the antenna. However if you wish to receive Digital Terrestrial broadcasts (DVB), you need to obtain a digital receiver for Terrestrial Digital Broadcasts. It can be easily connected to your TV.
Nov 11, 2008 | Televison & Video
Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Dec 12, 2007 | Refrigerators
Reception
"Sat" stands for satellite signal. "Ter" shows the signal from a terrestrial repeater. It's not uncommon to have 0 bars on the Ter setting. Where is your antenna placed?
Jul 05, 2007 | JVC KT-PK2000 SIRIUS Radio Receiver with...
Home Logo
474 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
