Question about Koiiler XM-6666W Car Audio Amplifier
Amp not getting any power after replacing deck.
I have a koiiler amp with a 350 watt sub, but once I switched out the deck for a newer one, the amp does not power on anymore. I tried tweaking the subwoofer options in my deck but it never seems to turn back on. I heard there was a trick you needed to do for it to power on again. I checked my grounds and connections and all are solid. It has happened before, and my cousin took the car and fixed it without telling me how he did it.
  • 156 Answers
If the amp doesn't power on at all after switching the deck, the most likely problem is the remote turn-on wire. (The subwoofer options might prevent sound from reaching the amp, but it would still switch on). Where is the remote wire from the amplifier connected at the back of the new deck?
Posted on Aug 07, 2007
How do i get full power out of my kenwood kac-1520s amplifier hooked up to two 12" audiobahn 400 watt subwoofers
Your amp is under powered for those speakers (350 max. watt). Even if your subs were 2 ohm your amp will only put out 75 watts X 2 at 2 ohms, if you bridge that amp you might be asking for trouble . I'm guessing there both 4 ohm. Look around for a 2 ohm stable mono amp with more power and you won't be sorry. Ray
Apr 23, 2014 | Car Audio & Video
Not getting any output from subwoofer, all connections are right,everything is on.
DOUBLE CHECK YOUR RCA CABLES. MAKE SURE THEY R GOOD & THAT THIER IN THE RIGHT SPOT ON THE AMP AND RADIO DECK.IF YOUR LIGHTS COME ON. THEN TRY THIS........ IF THAT DOES NOT WORK. CHECK TO SEE IF YOUR SUBS R CONN IN THE SUB BOX.IT COULD B SOMETHING THAT SMALL
May 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
I'm having problems with my subs (2 pionner preimer 12 inch subs 350 watt rms)and amp 2000 watt 2 channel(VS3506)the on light is still illumated soild green and the power is on the capactor but when i...
is ground on capacitor hooked up to gnd on amplifier ? if so it could be ya problem . ground cap to chassis and amp to chassis. try amp WITHOUT CAP and see what happens . Cap may also need charging with a resistor first . I'd remove cap(for now ) and retest amp for normal operation. Go from there.
Jun 13, 2010 | American Pro VS3507 Car Amp
Koiiler XM8787 Amp power problem
Sometimes i goes into protection when the amp is overloading with power.. Or the amp is touching metal.. Or the ground wire aint in the right place..Or check your RCA's, Speaker wires? if their earthing your amp..
Jan 13, 2010 | Koiiler XM-8787C Car Audio Amplifier
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Wet Amp
you probably too out an output on the amplifier. Will need repair.
Dec 24, 2008 | Koiiler XM-7676W Car Audio Amplifier
Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
May 11, 2007 | Koiiler XM-7676W Car Audio Amplifier
Koiiler XM-6666W Car Audio Amplifier Logo
236 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
