Question about Science & Laboratory
What is a bunsen burner? - Science & Laboratory
    Problem Solver:
  • 12 Answers
A bunsen burner produces a small flame, it is used in laboratories for heating, sterilizing or combustion
Posted on Apr 29, 2013
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
Clean heat exchanger
It needs to be removed and power washed. This is not always a DIY project, unless you have a strong back and are mechanically inclined. The heavy sooting indicates that the heater is not getting enough gas. Remember bunsen burners? Same deal, we want a blue flame (non sooting), not an orange flame. The culprit is usually an undersized gas line to the heater, or a smaller gas meter than the heater requires.
Jan 04, 2013 | Hayward H-series Electronic Gas Pool...
Can I use a lantern as a Bunsen burner?
No! It is not meant for that purpose and could cause major damage. You should only use lanterns as directed.
Jul 09, 2012 | Camping, Backpacking & Hiking
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
I have an endless summer 92000 table top propane heater. Lights fine, but the flame does not burn at the edge of the burner. Instead, it only burns in the very center of the burner... much like a Bunsen...
Actually, it's a gas pressure issue. But, it's fairly easy to solve. First, you need to be sure that your LP Tank has a sufficient amount of gas. If it does, turn the propane tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Then reconnect the hose to the tank and turn the valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner as you normally do and turn the burner flames to HIGH. Has the burner flame returned to normal? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If it didn't solve the problem, you will need to replace the heater's hose/regulator assembly. Generally, i's the same type that a gas grill uses. So, it won't be hard to find one.
Hope this helped to troubleshoot and solve your problem. Please let me know.
Apr 30, 2011 | Endless Summer 92000 Table Top Patio...
Cadac eazi chef flame burns yellow and makes a lot of soot.This happened after i tried to light it and there was some kind of blow back and some smoke but no visible flame. I have striped it down as far as...
Yellow flame = not enough air. (Remember using Bunsen burners in school science lab? Air hole closed = yellow flame). Have you twisted the main metal tube (whilst trying to remove the burner assembly)? Remove the gas tube and metal plate (6 small cross headed screws). Draw out the gas valve. Look into the metal tube. You should see 3 slotted holes - the air holes. On mine they had twisted and were blocked by the plastic of the leg assembly. Using a good pair of pipe grips, rotate the metal tube until the air holes are clear. Then re-assemble. My Cadac Eazy Chef now works like new.
Jul 01, 2009 | Grilling
High flame on Mabe Gas Stove
The gas supply pressure could be too high and it could be worth checking or if your supply isn't regulated, try fitting a regulator. Maybe the regulator is faulty if you have one.
From memory I think most domestic gas appliances need a supply pressure of 11 inches on a water manometer. Butane pressures can become quite high in warm weather (and drop to zero at freezing point).
Perhaps your new cooker is jetted for natural gas (methane). As that fuel gas has a lower calorific value than butane the jets would probably be bigger.
As a temporary measure you could try using a hotplate for simmering. I have a gadget that is two sheets of perforated steel with an air gap of about half an inch between them. It is nicely made with a useful handle and a loop for hanging and when placed over a low gas flame it allows me to place the glass coffee pot on it with no chance of damage.
Someone local could surely make you such a gadget if you don't find an everyday item that could be used. A car brake drum would lift your simmering pan a few inches and tend to diffuse the heat...
In the laboratory at school there was an asbestos pad to fit over the bunsen burner so flasks could be heated more gently.
I suggest you take a walk and look around with different eyes to see what you can find...
Mar 25, 2017 | Kitchen Ranges
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Science & Laboratory Logo
575 people viewed this question
Top Science & Laboratory Experts
William McMath
Tom Chichester
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
