Question about Canon C-exv11 Perfect Boxes Black Toner Ir2270 Ir2870 Ir2230 9629a002[aa
Scangear tools shows disable scanner for dept id management is not present
  • 17 Answers
SOURCE: canon iR2016J
Dept. ID is activated that is why it is asking you to enter it. If you are not needing the function you can ask the local service provider to check the settings of your machine.
Posted on Feb 21, 2009
  • 10 Answers
SOURCE: Image runner 2230- computer not recognizing IP adress for scanner
you must be shore that the cable between the copier and the co mputer is cross cabel and connected if there is a switch put normal cable
and then be shore that the diference between the two ip.s is smal as the computer ip 192.168.1.20
and the copier ip 192.168.1.30
Posted on May 02, 2009
  • 117 Answers
SOURCE: HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
Posted on May 06, 2009
SOURCE: Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Posted on Sep 01, 2009
  • 332 Answers
SOURCE: Have Canon DR-3020 scanner. Installed,
I have worked on Canon scanners for many years and I am very familiar with the scanner you have now. That model of scanner will not work like a convential scanner do to its age and compatibilty with todays software. I have found a website that will allow you to download capture perfect to use on your scanner. If you continue to have problems you might want to email Canon directly to ask for a link that will be more specific to your scanner. Just remember when that scanner came out Windows 95 was state of the art for software. Since that time Microsoft has gone through several upgrades to windows. Here is the link and if you need any thing else let me know. I am very good with your model of scanner. I hope this helps you out.
http://www.driversquad.com/driver.php?option=o&prodid=60&cust=canon+scanner+software_AD_www.google.com_&channel=&subid=201_US*DR_o&roia=!iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
Posted on Apr 01, 2011
Hi, I have Canon iR2018 connected on network. I want to know if it is possible to use it for scanning documents with multiple pages (eg. books) and store the scanned documents on a PC connected in the...
you need to install colour network scangear. Its available in the driver cd or you can download it from canon's site. Install the driver. select scangear tool from programs. put the printer in scanner mode then click search. the scanner and ip address will be listed.click it and then click select. then exit from the window. Color network scangear is available for windows only. Now for scanning you need
(i) windows word 2007
insert>picture>from scanner/camera and you will get scanning window.
(ii)in earlier version of ms office
there will be office document scanning tool
select scanner
you will get scanner window
(iii) photoshop
file> import
you will have to select scanner
then you will get the window for scanning.
(iv) word 2008
clip manager> insert clip
select custom insert
Apr 14, 2011 | Office Equipment & Supplies
Today I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution...
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
Oct 23, 2010 | Canon iR 2022 Printer
Unable to scan a document
Ok have you installed ScanGear? and ALL the right drivers from the DVD or web site? You MUST install BOTH Printer Z& Scanner Drivers and ScanGear, you use ScanGear to scan with...it will work if drivers are installed correctly. Did you install as Administrator? If a 64 bit system,have you disabled driver signing at bootup press F8 and do so if not. Below is a link for the up-to-date manual. http://www.retrevo.com/support/Canon-MP470-Multifunction-Printers-manual/id/3124ci176/t/2/
Anyway here is a link for a scanning package it doesn't use any driver, you can use this to check functionality of scanner.
www.hamrick.com/
Mar 04, 2010 | Office Equipment & Supplies
Scanning question
The Machine must be connected to a network.Download Network Scangear software driver from the Canon webside,install it on your destop.After installation open the Scangear tool and select the discover button.The scangear will search for the machine on the network.As soon as it has discover the machine the ip address will show in the tool.Select the Machine and close the scangear tool.Select the scan button and set it to online.
Now you can scan in to a program like word or exel by Insert a picture from scanner.
Dec 14, 2009 | Canon imageRUNNER 5000 Copier
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
May 06, 2009 | Canon imageRunner C3100 Copier
How to access IR22016 configuration using IE? i want to setup dept. ID and password using IE.
Print a user data list.
Find your IP address. Enter the IP address into your web browser. This will present you with the RemoteUI interface.
Go to additional functions and select department ID management.
You can also do this on models that have a touch screen by pressing additional functions and pressing the department id management button.
May 06, 2009 | Canon imageRUNNER 2200
I have ir3300 how can scan as pdf formate? please advice me
my canon 3300 all in one printer (image runner) pdf files print very slowly
May 04, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Mar 09, 2009 | Canon imageRUNNER 5000 Copier
Canon C-exv11 Perfect Boxes Black Toner Ir2270 Ir2870 Ir2230 9629a002[aa Logo
181 people viewed this question
old marine
old marine
