Computer cpu power button broken - Computers & Internet
    Top Expert:
  • Computers & ... Master
  • 49,129 Answers
If it is a brand computer one should be available as spare parts. If it is a generic cabinet try to get one from a reputable computer repairer He will need the cabinet (tower or case) to see what it looks like.
Posted on Apr 29, 2013
Which component may be in fault if the computer does not boot and POST is not executed?
"I replaced a broken hook that holds the processor cooling unit in place with a spare metal foil"
Most likely that is the problem. I am not sure what you did to replace the lock-down snap, but if that has loosened and the CPU heatsink shifted even a little the unit will not boot. It requires a firm, level, solid mounting. I have no idea if you removed the CPU or not, but if so you may have broken the bond of the thermal grease applied to the bottom of the heatsink; if so, the CPU overheats almost immediately and the unit shuts down to prevent damage to the CPU.
If you need more in-depth help, go here: www.suggest-a-fix.com
This is a free computer help forum where I (and others) hang out. Post in the Hardware section and I will be along. My screen name is "ranchhand".
May 21, 2014 | ASUSTeK COMPUTER Asus A8v-e Se Via K8t890...
Desktop computer fan is not working what is the problem, the desk start and stop after 3 seconds
check the power cable that goes from the CPU fan to the mother board. it could be lose off or broken. if broken you will need to replace fan/heat sink with a new one. if disconnected look for a place on the motherboard with 4 little pins sticking up. check to see if it says CPU fan next to them if so plug it in.typically its close to the edge of the motherboard near the CPU.
Sep 16, 2012 | Computers & Internet
I have a Hp Pavilion desktop computer. I unplug the CPU and relocated it to another desk in my home. When I went to plug it back in the green light on the back flashes but it will not power up. Is the...
it is a pretty good chance that your power source is broken, but another one is the mother board. take the source from your other computer and test it on this hp pavilion. if it doesn't start, take the cpu from the other computer and test it on this one, first with its original source and after with the source from the other one (the one with the cpu)
Jan 25, 2010 | HP Computers & Internet
Machine won't turn on . Period
Could be a bad power supply or a dead cpu. I would start by changing power supplies with one that is working if you have a spare computer with an ATX power supply. It is nolt very common but could be as simple as a defective power switch. How does the switch feel when it is pushed? Does it spring back or feel like something is broken. Most of the time when I have repaired a PC that does absouloutley nothing when the power button is pressed....dead CPU. You could also try leaving the plug disconnected for 20 minutes....maybe something in the powers supply is heating up. They will store power even when the computer is off.
Sep 13, 2009 | E-Machines eMachines Desktop PC
Computer won't start up
sounds like the cpu is dead, if your fan was full of dust theres a high chance it wasnt working properly for a while which would of caused the cpu to fry from lack of proper cooling and also the dust in the vents would have prevented heat from escapeing so its highly probable that the cpu is dead try replaceing it, i cannot gaurentee that anything else internally got fried from the heat tho, i had a similar problem a week ago
May 03, 2009 | Computers & Internet
Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Jan 07, 2009 | E-Machines eMachines Desktop PC
My hp dc 7600, stop to work and now don't power on. When I press the power button the computer start the fan cool and then turn off.
Big chance you've got a broken motherboard...
Maybe your CPU is broken...
Check your motherboard for 'swollen capacitors'.
Instead of flat, it will have a convex top.
You can also have someone who knows a bit more of computers look after it...
Mar 29, 2008 | Dell OptiPlex GX260 PC Desktop
EMachine won't turn on
unplug the power cords and let it sit for about 5 to 10 min. just like the cable box sometimes the brains have to be reset than make sure all plugs a lined up and tight .
Hope this gets ya back on line.
Dec 01, 2007 | E-Machines eMachines Desktop PC
Can't turn on Computer
Have you attached the CPU power cable from the PSU to the CPU power terminal next to the CPU. Double check you have the power and reset connectors tthe correct way around.
Jan 28, 2007 | NZXT GUARDIAN ATX Mid-Tower Case
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
