Question about Kodak EasyShare DX6490 Digital Camera
Flash won't work - possible bulb failure?
I have a Kodak DX6490 and the flash has stopped working. I have tried an alternative battery (fully charged), and the flash is open but when I try to activate it by pressing the flash button, the flash icon just flashes on the display, then stops. I suspect the flash bulb has blown. Does anyone know whether it is economical to repair, or whether it is possible to do yourself? Anyone know likely costs or where parts can be obtained from? Many thanks, Dean.
    Genius:
  • 2,985 Answers
Check Kodak for repair quotes likely hood not economical though
Posted on Sep 04, 2007
SOURCE:
The built in flash has stopped working
There is a small switch inside the flash flip up and it will get broken. Can only be replaced by someone with experience. You will do more damage to the camera trying to fix it. You can purchase a replacement for about $35 on Ebay or now is the time to upgrade.
May 26, 2014 | Kodak EasyShare DX6490 Digital Camera
Kodak easyshare C183 flash not working
Check settigns or possible burned bulb.
Aug 23, 2012 | Kodak Easyshare C183
My camera keeps saying unrecognized file format when i take a pic. I have a kodak easy share dx6490. Help?
dear sir,
the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest kodak service centre..
thank you...take care
Oct 08, 2010 | Kodak EasyShare DX6490 Digital Camera
My Kodak Easy Share DX6490 will not turn on. When I place it on the charging dock, the lights flash like it is transferring photos to my computer and the flashing won't stop even if I remove the camera...
Hello, sounds like you have a faulty battery,if the battery is several years old it will lose the capacity to boot the camera and the dock is trying to charge a defective battery,if you get a new battery, charge it for at least 6 hours or more.Hope this solves your problem.
Regards,Russell
Aug 16, 2010 | Kodak EasyShare DX6490 Digital Camera
The flash doesn't work
Hi there if you using the fully charged battery & not find the flash then replace the flash tube. Because the flash bulb/tube is cut off.
May 21, 2010 | Kodak EasyShare M1033 Digital Camera
Kodak DX6490 camera doesn't turn on. The light continueously blinks.
Hello Cynthia, Well there can be several reasons for this, First thing is to try a known good charged battery as these have a problem as they age not having enough power to boot the camera which requires quite a bit of power to start because of turning on the display, operating the lens motor,charging the flash,etc. This would be my first check before you go any further.
Best Regards, Russell
Mar 08, 2010 | Kodak EasyShare DX6490 Digital Camera
Help! I've dropped my Kodak dx6490. All modes on the mode dial flash. None of the modes work and camera won't turn off unless I take out the battery. BGS
Sounds like you will need to send it in for service. Get an estimate as it might be a better spend of your money to just buy a newer camera.
Jan 19, 2009 | Kodak EasyShare DX6490 Digital Camera
DX6490 won't work on battery only
I presume the camera is out of warranty?
There are many possible problems..
would the old battery charge on the fast charger at all or did it do strange things (dont do it now to try), If the battery was shorted, and you tried to charge it on the dock it may have damaged the cameras internal power supply, which is quite a complicated device, there are fuses but they are absolutely tiny and you need special equipment to fit them properly.
Also the flash capacitor lives on the power board which can keep its charge for quite some time at up to 300v at a substantial current and will make you drop the camera (at least) if it bites you.. :) so from the safety angle if you don't have at least some electronic training I cant recommend opening the camera..
The only possible suggestion that is a relitively easy fix is that the battery contacts may be bent or dirty.
Beyond that as I currently don't have my test dx6490 (used for checking voltages with units in for repair etc..) .. the next try is the dc socket, it may be damaged, or contaminated. try inserting and removing quite a few times and maybe using a VERY small amount of electrical switch cleaner.
Unfortunately to get to the socket if it is broken requires the whole camera be striped down as its just about the first board you fit when re assembling.
If you are adventurous, probably the easiest route to getting a camera back up would be to buy a faulty one from ebay. One with a broken screen or mode switch would be the easiest fix as you only need to remove the back and disconect and reconnect three ribbon cables.
Next would be a lens swap for one with a broken lens but requires quite a significant amount more work.
although the most difficult bit in both procedures is getting the diopter knob (eyepiece focus) on and off which in most cases means a small amount of damage will be done to the eye piece but nothing really bad, just cosmetic (kodak would replace the bit)...
If i can be any more help drop me a line....
best of luck
Jun 01, 2008 | Kodak EasyShare DX6490 Digital Camera
Fix flash on kodak z740
to try if the flash is working..
*Turn off the camera.
*Install a set of new or fully charged batteries into the camera.
*Turn on the camera.
*Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash.
If the flash of your camera will not work, refer to www.kodak.com/go/itg for interactive troubleshooting and repair
Apr 09, 2008 | Kodak EasyShare Z740 Digital Camera
Flash does not work, have good batterys
probably there's a problem with the bulb of the flash itself and the cam would need to be serviced, contact kodak for that
you can try this too
use lithium/ni-mh> powercycle (remove batt and card)> put back batt> turn to PASM> try fill flash (at the top of the cam, use flash button), flash button at the center part of the screen should be a plain lightnightning bolt, no A beside nor line across it
take a picture
if still no flash - arrange repair with kodak
1 800 235 6325
Nov 14, 2007 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
343 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
