Question about Sony Ericsson Cell Phones
Dryer turns but dont heat
HEAT PROBLEAM
    Top Expert:
  • Sony Ericsson Master
  • 42,818 Answers
Check for burnt out heater element.
Posted on Apr 29, 2013
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
My dryer dont warm up at all its stay cold when turn on .lg dlg5966g
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 08, 2011 | LG Dryers
My dryer heats up but is not drying my laundry.. What's wrong?
here is a fuw things to check first,,,, is the vents clear the dryer need to breath freely,,,is the drum turning around freely and not sticking due to belt slip,,, how dry are the cloths going ino the dryer,,,,(as the winer is here the air going in is cooler so takes more heat to warm it up) uk temp -2 degrees??? cold! how much are you putting in it? can it tumble freely,,,(no big knots in it?) try turning the heat up to full heat? and drying for longer,,,if all that fails,,,dont do any more washing??
Nov 28, 2010 | Kenmore Dryers
My kenmore 600 gas dryer dont heat up. gas is on electricity its fine it turn on it works fine but just not heats up.
Disconnect the rear vent off the dryer itself and try again. If heat does work the vent tubing is clogged
Oct 06, 2010 | Kenmore 600 6962 Dryer
My dryer turns with no heat. I also dont feel any air from the exhaust vent. Ive heard that it could be a fuse or the breaker. Where are the fuses located? How do i reset the breaker on the dryer?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 05, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer does not heat up
Unplug the dryer. Look for blockage.4b24ab7.jpgIf you have air restrictions your heater element might be OK. 142c967.jpga4caa20.jpgIf all these components check good and you still don't have heat you might have a timer problem or an electrical problem. The timer has a leg going directly to the heater element. The load is high and overtime the contacts inside that timer get burntc97b4dc.jpgAnother thing it could be it the breaker. The motor runs on 120 volts. The heater however runs on 240 volts. If the breaker is worn on the heat load side then the dryer will work but their will be no heat.7e5d468.jpgIf it turns out to be a limit instead of the heater element then clean out the dryerd60b014.jpg8006b2f.jpgb57aa0b.jpg0fe9a0b.jpg3aea907.jpg2b993f6.jpgService manual for kenmore
More Here
Aug 04, 2010 | Kenmore 64742 Electric Dryer
Clothes dont dry no heat Maytag gas dryer runs well but no heat clothes are damp
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
May 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer turns on but i dont get heat
First check your venting if all is clear it could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or ignitor. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Mar 31, 2010 | Kenmore 63942 Dryer
Dono heat and timer dont turn
HI. Due to the fact that the timer is not advancing, this will lead me to believe that the timer is the culprit here. The timer is equipped with a motor. this motor, when energized, will advance the timer dial, thus, activating the unit, and progressing the cycle. If the motor is damaged, as in your case, the unit will not heat, or run correctly. Simply replacing the timer control module will correct this problem.
Replace this damaged timer mechanism asap.
Dec 04, 2009 | Estate TEDX640JQ Electric Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Cell Phones Logo
41 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
