Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
SD Card capacity and make problem with IXUS40/SD300
Please tell me what is the maximum SD Card capacity that IXUS40 can take. Please suggest the best make(s) also. So far I understand that Sandisk is most preferred.
  • 641 Answers
Basally, you are not limited with the SD card capacity. It is an "economic" decision only. Sandisk is one of the best companies for it.
Posted on Aug 07, 2007
  • Dov Dror Aug 07, 2007
    Let us know if you have another or a better answer for your question ???!
    It might help other people that are looking for this information.
SOURCE:
Binatone Homesurf 744 - put in micro SD card but nothing will save to it although it says it is there (can unmount it).
Please make sure the capacity of your microSD card is not larger than the maximum card capacity allowed by your device. For example, if the maximum card capacity allowed by your device is 16 GB and your card capacity is 32 GB, your device may not recognize it. And is the "unmount SD card" option grayed out or solid ?
Hope this helps.
Dec 16, 2014 | Cell Phones
Www samsungcamera com
Some cameras have a maximum limit to the capacity of memory card that can be used. Please make sure that you have the right capacity card. There is also a lock (yellow tab on the side) on SD card. Make sure that it is not in the 'lock' position.
Aug 24, 2014 | Samsung Digimax S800 Digital Camera
Hi there,I was wondering if a 4GB SDHC card was suitable for a Cannon IXUS 4.0 or not? I can't seem to format it?
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. It is often difficult to find out the maximum capacity card that a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
Dec 01, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
When i insert my 4Gig SDHC card into my Panasonic DMC LS2 camera , it gives a card error message , please check SD card ! What do i do ?
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 14, 2010 | Panasonic Lumix DMC-LS2 Digital Camera
I have the JVC above and it requires an SD card. I inserted an SDHC card and it gave me an error. SD and SDHC are not the same? When I did try to but SD card only still on its label has SDHC. To be honest...
You are correct. SD and SDHC are not the same.
SDHC stands for Secure Digital High Capacity. It was a technical evolution which broke the 4GB maximum capacity of SD cards and allows up to 32GB. In turn they are eventually due to be superseded by SDXC cards (ecure Digital eXtended Capacity) which allow a maximum of 2TB.
May 30, 2010 | JVC Everio GZ-MG37 Camcorder
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
What is the maximum size of sd-card for the ixus 40 ??
Hi there.
As far as i know the maximum SD card support is 8BG
Sandisk is my recommended card to you
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Problem during assembly in reverse order on Canon SD300 (Ixus40)
Not quite sure where you are having the problem with your camera, but there are several places on the internet that can help fix your camera and/or lens.
Here is one listing I found on eBay for you - http://cgi.ebay.com/Canon-SD500-Camera-LENS-BARRIER-SHUTTER-FLAPS-REPAIR_W0QQitemZ260164183646QQihZ016QQcategoryZ64352QQcmdZViewItem
You can email him your model number and he should be able to help you.
Best of luck!
Dec 20, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
114 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
