Question about Mitsubishi Heating & Cooling
Msz g12sv left green light flashes continuously, and no warm air.
5 Suggested Answers
  • 5 Answers
SOURCE: mitsubishi msz-a24yv air conditioner.keeps turning
a/c units have ways of protecting their major components. if you have a freon leak it could be shutting down on low pressure safety switch. or it could be overcharged with freon and be shutting off on high pressure, although high pressure safeties usually have a manual reset. therefore a low pressure
problem is more likely
Posted on Dec 10, 2008
hvac1960
  • 2133 Answers
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
hvac1960
  • 2133 Answers
SOURCE: Mitsubishi msz-ga60va not cooling.
You didn't give any error code. But, still, I hope unit need complete service. Do it and check again.
Posted on Jan 08, 2011
shastalaker7
  • 1515 Answers
SOURCE: I have a Mitsubishi Mr. Slim Model MSZ-A09NA. We
Hi, it sounds like you may have lost the blower motor due to the power surge. Normally, it would kick the breaker off.The code is just telling you something is not right as you know. You can try turning off the breaker to the indoor unit for 10 minutes or so, and reset it to see if the blower will start. If you have the manual, that might tell you what the code or light is. Its more then likely a 220 volt indoor unit. Sometimes on a double pole breaker, only one half of it will trip in a power surge. Check to see if this is the case, as you may only be getting 120 volts to run the vanes. If its half way tripped, turn it off hard, and back on hard. that may be your problem. If not, call the service tech, and just tell him it stopped working. He will come out at know charge to you. I bet its your breaker though. Please let me know.
Sincerely,
Shastalaker7
A/C Contractor
Posted on Jun 06, 2011
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
How do I clean Mr Slim MSZ 24NA
usa.mylinkdrive.com/.../MSZ-MSY-A09-24NA_GA24NA_Service_OB
Sep 19, 2014 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
What does flashing green message light mean on norstar?
M7310 does not have a red light.
And even if it did you answered your own question....you left that phone a message so now it flashes to let that person know they have a message.
F65 to see who left message
F#65 to clear MSG and/or light.
Jul 24, 2012 | NorStar Meridian M7310 Phone
I have an air conditioner Mitsubishi MSZ-A26YV, it has stopped heating, even if it's on the heat setting [sun emblem] and is set to highest temp, only cold air comes out, otherwise it does all other...
It's not indicated to turn directly from cooling mode to heating mode. You must wait about two or three minutes before the change. After the spliter start, you must wait few minutes to get hot air.
Mar 30, 2011 | Mitsubishi MSZ-A24NA Split System Air...
Mitsubishi msz-ga60va not cooling. Did same last year then righted itself. Left light is flashing. and no cool air. Please help.
Jan 07, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
There is no cooling. After running a short time, the indoor unit only, the left LED blinks. The right LED turns off. I can't find anything about this. Could I be low on gas? Regards, Charles
look around them lights.., on the circuit boards.. or on the diagram.. them blinks are codes. so find the codes that are their .they will tell you the problem... p/s like 3 short flashes may mean fuse s are out at the dissconnect .you have to look and you will find it good luck
Aug 22, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Will not blow cold air
pls check your remote setting
Apr 27, 2009 | Heating & Cooling
Mitsubishi msz-a24yv air conditioner.keeps turning itself off and the opertation light keeps flashing
Dec 08, 2008 | Heating & Cooling
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Heating & Cooling Logo
43 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
