Question about Emulex NetQue Pro2 (NP02) Print Server
How to install pocket printer server
I have install to pocket print server.I dont know how to install. please help Pocket printer server Manufacturer- Emulex Corporation Model No.- NQP0 Thanks & Regards Shirish Yamagekar
    Genius:
  • 2,985 Answers
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Posted on Aug 07, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Reset ESI 2833 until red light turned green. Network Printer still not responding
Check the IP Address of the 2833. I believe there is a gray button you can depress to print out a configuration sheet. If the wireless modem was also your router, you may have a different IP address range and will need to set the 2833 accordingly.
Sep 03, 2013 | Extended Systems Pocket Print Server
Sipix Pocket Printer won't print.
First check to make sure that you have the correct com port selected.
then set the com port to use these settings.
11520 Bits per second
8 data bits
no parity
2 stop bits
hardware flow control
Jul 15, 2017 | SiPix Pocket Printer Thermal
Sipix pocket printer a6 window 7 driver
Windows 7 should be able to use Vista or XP drivers, but you should have no trouble downloading Win7 drivers:
http://www.driver-fix.com/driverdetective.php?t=Pocket%20Printer%20A6%20Drivers
Jan 17, 2010 | SiPix Pocket Printer A6 Mobile Thermal
My network HP laserjet 4Vprinter and ESI 2830 pocket print server suddenly gives an error message "No RARP/BootP Server". How can I fix this?
the information in the link is too long to paste but you may want to look at it.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - TCP/IP, Messages on Configuration Page or Self-Test Page
Get the IP address subnet and gateway address of a computer in the same network.
Usingthe LJ5's control panel, setup a static IP for the Jet Direct using thenumbers you got from the Laptop, except change the last number of theIP to one that is not being currently being used. Perhaps adding 5 or10 to the highest number in use.
Here are the steps to configure the LJ5.
1.Press MENU, repeatedly, until the following message appears on thecontrol panel: HP LaserJet 5/5n/5m and the original Color LaserJet: HPMIO MENU
2. Press ITEM. CFG NETWORK=NO* will appear.
3. Press the PLUS button once. CFG NETWORK=YES* will appear.
4. Press ENTER or SELECT.
5. Press ITEM repeatedly until CFG TCP/IP=NO* appears.
6. Press the PLUS button. CFG TCP/IP=YES* will appear.
7. Press ENTER or SELECT.
8. Press ITEM until BOOTP=YES* appears.
9. Press the PLUS button. BOOTP=NO will appear.
o When using BootP or DHCP, keep the setting BOOTP=YES*.
o The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect.
o No other TCP/IP configuring is necessary.
10. Press ENTER or SELECT.
11. Press ITEM. IP BYTE 1 = (value) will appear.
12.Press the PLUS button until the value of the first byte of the IPaddress appears on the control-panel display. By pressing SHIFT and thePLUS button, the value will decrease.
13. Press ENTER or SELECT.
14. Press ITEM to continue. Repeat Steps 11-13 to configure the remaining bytes of the IP address.
15.Repeat Steps 11-13 to configure the subnet mask bytes (SM BYTE 1=),syslog server IP address (LG BYTE 1=), default gateway (GW BYTE 1=),and timeout (TIMEOUT=).
16. Press ONLINE. Print a self-test page to verify the IP settings.
17. If the test page does not show the correct settings, power cycle the printer and reprint the test page.
else: have the printserver reinstalled
www.nls.com/common/pdfs/v307n10.pdf
Nov 24, 2009 | Extended Systems Pocket Print Server
Ho do I print a config page from the extend print
If I remember correctly there is a reset/print configuration button on the pocket print server. With it connected and the printer on, press it once and it should print out a configuration sheet with its settings. If that doesn't work, disconnect the power and with the button held in, reconnect the power and release the button.
Oct 09, 2009 | Extended Systems Computers & Internet
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
hi again!!!
how are you? Pls try the following to troubleshoot....
1. Remove all memory cards
2. Disable Wireless
3. Disable any infared device drivers such as a keyboard...
4. Under settings clear the checkbox under Beam.
5. Soft Reset
6. Install Pocket PrintCE
Pocket Print CE
7. Soft Reset
8. Try to print if you can or cant continue
9. Soft Reset
10. Install Sipix driver
11. Soft Reset
12. Try to print if you can print wait a few days make sure its still working. Then when ready remove Print Pocket CE
And....some info...
Software
The Pocket Printer uses a special version of IS/Complete's IrPrint. This allows it to print from all the built-in applications. I think it handles this in a very cool way. In order to print something, just launch the IrPrint application. This brings up a screen with large buttons to open any of the built-in apps. Tap on one of these and the actual application will be opened. You can do anything you would normally do in this app, plus each now has an "IrPrint" option added to its first drop-down window. Clicking on this will open the print driver.
That explanation might not be clear so I'll walk through an example. Say you have an Address Book entry to want to print. First, open the SiPix application and choose Address. This will open the Address Book app allowing you to look up the address you are interested in.This is the regular Address Book; you could add, edit, or delete any entry at this point. But instead you want to print one so you find it and open it. If you tap on the Menu silk screen button the Record drop-down box will appear. At the bottom of this drop-down box is a new entry: IrPrint. Tap on it. At this point, it is necessary to be pointing your palm's IR port at the Pocket Printer's. The Palm will spent a few seconds finding the printer then open a window of options.
Oct 11, 2008 | SiPix Pocket Printer A6 Mobile Thermal
ExtendNet Pocket Printer ESI-2841 - Link Light fails to come on.
Did you connect it hrough a swirch with a network cable, or to a pc with a crossover? It is not a smart adapter, can't do midi or tx.
Oct 31, 2007 | Troy ExtendNet SX Print Server
ESI-2831 Drivers missing
Here is a Manual. As for the drivers came up short on them sry. www.nls.com/common/pdfs/v307n10.pdf
Apr 19, 2007 | Extended Systems Pocket Print Server
Print through the USB port to a USB printer
This capability is available as an installable option from 3rd party software vendors, and possibly from some printer manufacturers. A compatible printer with a Pocket PC 2002 driver is required. See www.Westtek.com
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Emulex NetQue Pro2 (NP02) Print Server Logo
454 people viewed this question
Top Emulex Computers & Internet Experts
Alun Cox
Are you an Emulex Computer and Internet Expert? Answer questions, earn points and help others
