Question about Toshiba Turquoise 10.1" NB505-N508TQ Netbook PC with Intel Atom N455 Processor and Windows 7 Starter (883974682959)
Computer does not work
When I turn on my laptop, the fan turns on for a few seconds and then stops. The hard drive does not sound like its on and the screen is black. No other light turns on except for the power light. I have been using my netbook in conditions that got it really hot (hot weather mostly). I tried my best to give my netbook adequate air ventilation, and I would shut it down when I felt it was too hot. I don't know if this has anything to do with it, but I installed linux mint on my comp and I think some proprietary drivers were not installed (because I didn't know how).
  • 156 Answers
Posted on Apr 29, 2013
Beni S-P
  • 1006 Answers
SOURCE: stopped working
I think u need to change ur hdd if ur hdd making GRRRRRRRR...If not so the problem is VGA!
Try in external monitor...If ur pc is ok in external monitor so problem is MONITOR and if still wont work in external monitor soo ur vga or motherboard have failed
Posted on Nov 09, 2007
jimbo6
  • 89 Answers
SOURCE: Toshiba Satellite A60 powers up then off after 2 seconds
Mark F K, truong808, does the cooling fan(s) blow or come on? If not, the system will sense tha ti is overheating and will shut down to prevent further damage. Also, a thermal sensor may be failing on the Mobo and thus keep the fan from initiating. The cheapest fix is to replace the fan. Worst case scenario is another Mobo may be the fix.
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Posted on Aug 16, 2008
  • 12 Answers
SOURCE: Toshiba Satellite Goes completley off! Black screen, NO POWER!
This problem is likely caused by overheating. The CPU reaches a temp to high and shuts the system down. When you try to turn it on the system is still to hot and it will not let the computer power on. You can try blowing out the fans and heat sink with an air compressor or can of compressed air. If this does not help the problem you may need to have thermal compound reapplied. If that does not fix it it will need a new heatsink/fan/
Posted on May 21, 2009
  • 99 Answers
SOURCE: Toshiba Satellite L25 series laptop doesn't power on
its a fried motherboard. any questions you can email me at meanness628@aim.com
Posted on Jun 30, 2009
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Reset button on a powerbook g4
The Powerbook G4 power button functions like a reset button if you hold the power button in for a few seconds until the computer powers down.
  1. Hold the power button in for a few seconds (until you see the screen turn off/go black and hear the fans & hard drive stop spinning).
  2. Press the power button again to turn your computer on.
  3. If you have more trouble, you may need to boot in Safe Mode or "perform a Safe Boot":
    Press and hold down the "Shift" key immediately after you hear the start-up tone. Release the "Shift" key when the gray Apple icon appears on the screen.
May 02, 2014 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Acer aspire 5532 won't start
I had the same identical problem with a Toshiba. I got hit with a 'rootkit'. It's like a virus on steroids. If it didn't cook your hard drive AND motherboard, a computer shop MIGHT have the necessary resources to fix it. Hopefully, you kept everything backed up.
Dec 28, 2012 | Acer Computers & Internet
I bought a Toshiba A665 S6070 and it freezes and then when I take the battery out and reboot. It wont. HDD doesnt starts for a few seconds and stops. I have reformatted to factory settings, cleaned all the...
The laptop sounds like it has motherboard issues, and possibly hard drive problems as well. The computer should be returned for exchange because it will get worse and reach a point that it will be come unusable, I strongly recommend taking it back the sooner the better.
Jan 12, 2011 | Toshiba Satellite A665-S6070 Notebook
Hi, I have bought this dell vostro 1015 laptop one and half year ago. Day before yesterday my windows XP hanged and I was unable to shut down. So I pressed power on button for few seconds to switch off...
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Oct 29, 2010 | Dell Vostro 1510 Laptop
When i press power buton computers, on/off led just blinks once,cpu fan turn few times and stop, power supply fan also turn few times and stop and computer does not start.
Possible bad power supply, hard drive, and or CPU. If there is a computer repair store close to you, I would take the hard drive to them and have it checked out thoroughly to make sure all the sectors are in tact and possibly have the power supply OHM'd to make sure the proper amount of voltage is coming out in order to turn the computer on in the first place.
Oct 11, 2009 | LG L1915S 19" LCD Monitor
Black, cannot boot up... etc.
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 02, 2009 | Acer Aspire 5520-5908 Notebook
Toshiba Turquoise 10.1" NB505-N508TQ Netbook PC with Intel Atom N455 Processor and Windows 7 Starter (883974682959) Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
