Question about HP Pavilion Computers & Internet
Download error restored my hp pavilion dv6 now when i try 2 reload programs i had on b4 not all just some of them i get message(internal error cloud installer will now close)did hard drive check all good there.please help thank u
  • HP Master
  • 5,660 Answers
Cloud installer?
So these programs are being reinstalled from a cloud, and using an installer?
I would download the program, and install it myself; without the cloud installer.
This, of course, if it is feasible to proceed in this manner.
What are the programs in question, if I may ask?
Also, is your anti-virus program interfering with the installer?
Post back in a Comment.
Regards,
joecoolvette
Posted on May 01, 2013
mnelsonix
  • 58 Answers
SOURCE: Error 0x400 100 130000 1002 while restoring factory image HP
I am assuming you are trying to reinstall Vista. Apparently, HP's recovery partition is less than perfect and the recovery disc you created is probably worthless. (and you can NOT make another one, they only let you make one!) You are not the only person to have this issue.
Here are some things you can try:
1) Borrow an OEM version of Vista from someone...anyone. It sounds like you are proficient with PC's and maybe you know someone who works in IT. Use your product key (25 digit key code) and you should be able to reinstall.
2) if you like Vista, buy yourself an OEM version. It will not have all the factory (HP, Dell, Acer, whatever) BS on it. It will positively work because your hardware if fine.
3) Put XP on it. Personally, I think Vista is a mess. Microsoft is working on "OS7" and soon Vista will be like "Millennium".
Sorry it's not an easy fix, but glad your hard drive and memory show no errors.
Posted on Mar 29, 2009
yboyandrei
  • 828 Answers
SOURCE: How to install xp in HP Pavilion dv6 1030 us
Partition and format the hard disk using the Windows XP Setup program loadTOCNode(2, 'moreinformation'); You can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps: Step 1: Partition the hard disk loadTOCNode(3, 'moreinformation');
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 (http://support.microsoft.com/kb/314859/ ) Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Posted on Aug 17, 2009
SOURCE: Every time I turn on my new PC I get a black
I have the exact same problem with my HP HDX 16. I would suggest calling the HP techcenter and exlaining the problem to them. Chances are they will want to take a look at it and will possibly replace your laptop. I haven't yet done this, but have allowed my computer to rest for a while. Leave it shut down for maybe 30-60mins and then try rebooting. Hopefully you will atleast be able to start it in safe mode with command promt. Open the command promt as the administrator and type CHKDSK which will perform a check for bad sectors in the hard drive. Hope this helps. otherwise give HP a call :)
Posted on Jan 08, 2010
catwacker
SOURCE: Repair manual for HP Pavilion dv6 1245 dx
Go to hp.com. Click on support and drivers tab. Select "See Support & Troubleshooting Information." Enter your laptop model number. dv6-1245dx. Click on "GO". See: "What Type Of Support Do You Need?" Choose MANUALS. Scroll down the page and select "HP PAVILION DV6 ENTERTAINMENT PC - MAINTENANCE AND SERVICE GUIDE". Download that PDF format. It is relatively easy to get to the ribbon cable that connects the touchpad to the motherboard. It is connected via a ZIF connector. I had a dv1331se and the touchpad stopped working. I just reseated the cable in the connector and all was well. Hope your solution is as easy as mine was. You'll have to remove the trimplate just in front of the keyboard. Be careful with the connectors there. The manual is well laid out and the diagrams easy to follow. Good luck. HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
Posted on Mar 16, 2010
  • 341 Answers
SOURCE: Low volume on my HP Pavilion dv6-1245
Open the audio panel (settings -> control panel -> Sounds and audio devices -> volume). Check that the volume slide is all the way to the right. Also, click on the "speaker volume" button and check it is all the way to the right
Posted on Mar 21, 2010
Internal Battery Error
Time to replace your laptop's main battery.
Dec 17, 2013 | HP Pavilion Computers & Internet
Computer error
I am assuming this is Windows 7? make sure you have run all windows updates and activated windows. It seems to be related to an archiving issue - make sure you EXTRACT all software from any ZIP files or WinRAR archives prior to installing.
Apr 29, 2013 | HP Pavilion Computers & Internet
Very slow after restoring to factory settings
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Jul 11, 2012 | HP Pavilion dv6-1122us Notebook
I have an HP dv6-3025dx, i am trying to restore the operating system to factory settings and i try to do that and it says windows cant load files... i get the error code 0xc00000e9 and i cant update my...
no fee from this site
no factory reset either
uninstall the operation system and then reinstall it from the disc or download
probably the best is to reformat the hard drive then reinstall the os
make sure that all files and folders are backed up onto an external hard drive first
Jul 02, 2017 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
I need the manual for this laptop hp pavilion dv6-3206ax
You can download it from the HP website under downloads. www.HP.com
May 16, 2011 | Computers & Internet
My hp pavilion dv6-1030us is all of a sudden not booting up. It turns on fine but when it comes to the loading screen that says Microsoft Corporation and has the loading bars running across the bottom it...
try going into safe mode F5. reboot and keep tapping F5 if you can get into safe mode try a system restore back to the time it was working. if not reload from recovery drive (F11 i think) or from recovery disc.
hope this helps.
Apr 29, 2010 | HP Pavilion dv6-1030us Notebook
Stop 0x00000007b appears on my hp pavilion dv2000
Try removing and reseating the memory.
Try to boot into safe mode ( F-7 ).
If you are good in safe mode, try a F-11 restoration and reload from factory.
Another idea, is to run the Hard disk utility in the BIOS setup. ( Last page )
If this message is not a memory fault error, it may be lost or missing data on the hard disk and will need to be reloaded.
Hope this helps.
Oct 03, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I have hp pavilion dv6 laptop windows xp drivers
I have the solution! Read this thread and install this version of XP 32-bit. I am currently running this version of Windows XP Pro 32-bit on my HP Pavilion dv6-1030us. IT WORKS!!! I promise. After you install that version of Windows XP 32-bit than follow the second link here. Good Luck.
Step 1) Download this OS here: http://www.mininova.org/tor/2863191
Step 2) Burn the ISO using your favorite ISO burner. (I use ImgBurn)
Step 3) Do a complete fresh install.
Step 4) Install these drivers: http://h30434.www3.hp.com/psg/board/message?board.id=OS&thread.id=9700&view=by_date_ascending&page=6
Step 4) The drivers on that page are post by Daniel, so please give him kudos for hunting down the entire driver list.
Step 5) Reboot and ENJOY!
-=Viralnexxus=-
Mar 11, 2009 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
