Question about Refrigerators
SAMSUNG RS21HSTPN (600L) problem of condensation inside the fridge section
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: the fridge section (top) is freezing pop and other
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Posted on Sep 07, 2011
I have a Samsung srs585hdis side by side fridge and there is quite a lot of water leaking from a cover behind the bottom veg baskets. What would cause this?
The evaporator condensate collection pan drain inside the fresh food section is clogged or blocked with ice. You will need to take the cover off to clean out the drain. Here is a link that shows the breakdown of parts for the fresh food section=> HERE
Here is a link to=> Leaking Refrigerators
This video only applies only because it shows examples of what is happening to your refrigerator
APPLIANCE 911
Dec 21, 2015 | Samsung Refrigerators
Fix leak inside Samsung refrigerator
water may not be leaking inside? What u may have is water condensation? this happens when u have a clogged or plugged evaporator drain plug line or bad seals on the door which allow air and moister to come in and CONDENSATE, THEREFORE WATER IN THE FRIDGE. U NEED TO CLEAN THE DRAIN LINE USE HOT WATER, AND A SOFT FLEX TUBING OF SOME TYPE
Feb 15, 2015 | Samsung Refrigerators
Does my fridge have a defrost timer? The first time the fridge quit working we had a repair person come figure out. He found the circulation fan was frozen in the back panel inside the fridge. He turned...
This is a very common problem with Samsung refrigerators especially the type that has two evaporators. The evaporator that is inside the fresh food section and will usally give people the most problems. The drain below the evaporator in the fresh food section will begin to freeze over or become blocked by gunk inside the drain line. When this happens it causes the fresh food section to retain water because with the drain blocked the moisture and defrost condensate water now have nowhere to go. Once that drain is blocked the freezing over of the evaporator will begin to happen more often slowing down defrost which again make problems worse. Clean the drain, make sure the refrigerator is level and confirm the model number of your refrigerator. Your model has no defrost timer and defrost are determined by the motherboard. There is a way to force defrost with your model from the motherboard but until the drain is cleaned out defrost will not help much because the water has no where to go but to freeze over the evaporator and fan area of the fresh food section evaporator. Is your model the?=>RF267AERS I am here if you have questions, Sea Breeze
RF267AERS Parts
Oct 21, 2013 | Samsung RF267AERS French Door Refrigerator
Fridge section has a flashing 4C temperature on the display
Have you checked compressor running, fans working, condenser clean etc?
Apr 28, 2012 | Samsung Refrigerators
Samsung refrigerator RS2556SH purchased Oct '05. Problem: Refrigerated side not cooling adequately. I removed vent cover to expose evaporator coil and discovered a few 1/2" tears in tubing, which appear...
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly. Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly. * Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches). * Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section. * Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working. * Compressor – Make sure your compressor is working with on and off clicking noises.
Aug 08, 2010 | Samsung RS2556 Side by Side Refrigerator
What is causing water to build up inside the refrigerator section? there is water in the crispers and on the shelves.
A condensation problem inside a fridge, normally means either, you are puting uncoverd food /or food that has a high water content (i.e.salads) into the fridge, which may be warmer than the inside temperature of the fridge, hence condensation(leaving the door open too long has the same effect)only remedy is paper towels in bottom of crisper so that salads dont go soggy.and wipe out fridge as often as needed.
Mar 10, 2010 | Whirlpool ES5FHAXS Side by Side...
Why is water is pooling at bottom of the fridge
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home.
Jan 05, 2010 | Fisher and Paykel Refrigerators
I get a puddle of water inside of the the refrig every a couple days, I have turn off the refrig, and blow with the fan for over 5 hours, hoping that will solve the issue, however that didn't work.
check the seals for leaks. condensation from warm air leaking into the fridge through bad seals collects on the inside. also, if condensation collects on the evaporator coils, it'll freeze. then when it goes into defrost mode, all of the frost and ice melts into a condensate pan under the fridge. if the tube to the pan is blocked, the condensate stays in the fridge. so, check the seals and check the condensate tube.
Nov 09, 2009 | Samsung RS2630SH Side by Side Refrigerator
Leaking in the freezer compartment
This is a common problem with all refrigerators. The problem is most likely to be in the defrost condensate drain line. Beginning in freezer and making its turns to condensate pan below your refrigerator.Send your model number and I will be able to point out where. Thank You
Jun 19, 2009 | Samsung Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
