Question about Arris Sb6120 Cable Modem Docsis 3.0 Sb 6120 Cableone Cox Time Warner Rcn
Turn off sap
I want the language to be English... Not Spanish how do I fix this?
Cant get 4-5 channels back to English, went to menu , put in English, still not English ,other TV in home same channel is in English
Hi Jeanne,
If you have the original remote control, tune to the channels that have Spanish language and press SAP on the remote control.
Hope this helps..
Oct 12, 2015 | Televison & Video
Model #VV2000 S # BOAA20050 CHANNEL SPEAKING SPANISH... NEED TO CHANGE TO ENGLISH QUASAR TV
Use your remote control to check the TV SAP settings. This is "second audio program" and is often used to carry the TV sound in another language. If SAP is turned on you won't notice it unless you tune to a channel where the SAP signal is present. Most remotes have a single button to control the audio settings, so it's easy to turn the feature on without knowing it by bumping the button. Turn off SAP and you should be back to English.
Mar 06, 2010 | Televison & Video
Vizio gallivea some tv channels are in spanish and no sounds
GO into the customer menu with the remote and look at the audio settings---I would bet you will find SAP has been selected; this will give you some channels in spanish( SAP means secondary audio program) Monday night football and some other programs offer this for Spanish speaking people. Change the setting to Stereo or Mts away from SAp
I do this here for free so if this helps you give me a vote here---if you have questions or need help contact me by replying to this post.
SD TECH (SAN DIEGO)
Aug 29, 2009 | Vizio GV42L 42 in. LCD Television
Want to stop VCR from using Spanish language on programs it records
Use SAP (or SAP/HI-FI) button on remote to cycle through the choices until you get to English or OFF.  Or use Setup Menu to select English language.
May 30, 2009 | Panasonic PV-V4525 VHS VCR
Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
Feb 06, 2009 | JVC AV27F476 27" TV
Sound
SAP is short for "second audio program" and is a way to send a second audio track along with the main one. In many areas stations use SAP to provide Spanish or other language sound for movies and other programs. If you have SAP turned on you don't know it until you tune to a channel where it's being used, and then you hear the other sound. Just turn SAP off using the remote control or TV menu.
Dec 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
My tv is on spanish how do i take it off
Spanish on the screen or Spanish through the speakers on some channels? If its the on-screen display that's in Spanish, you pick the language using the setup menu with the remote control. If you're getting Spanish through the speakers, you probably have turned on the SAP (second audio program) function. In some areas with a large enough population, SAP is often used to broadcast program audio in a different language. On channels with no SAP broadcast you don't hear any problems. The SAP function is usually controlled by a button on the remote and probably got pressed by accident.
Dec 01, 2008 | Hitachi 51F500 51" Rear Projection...
Sharp Liquid Crystal TV - Flat Screen - 1.5 years old
Go into the menu and under AUDIO and make sure that the sound is set to STEREO, and not SAP (second audio program). If you have a separate setting for SAP then shut it off.
Apr 23, 2008 | Televison & Video
Vcr spanish language
You may have your SAP settings turned on in your VCR. Check your setup menu and turn SAP off SAP stands for Secondary Audio Program, it allows for bilingual sound if the station is transmitting a SAP signal. Thank you,
Aug 27, 2007 | Sanyo VWM-900 VHS VCR
Audio in spanish when spanish is broadcasted
consult your service manual it has all the informaton you want.goodluck.f you do not have a service manual check with www.partstore.com
Nov 18, 2006 | Toshiba 24AF45 24" TV
Arris Sb6120 Cable Modem Docsis 3.0 Sb 6120 Cableone Cox Time Warner Rcn Logo
19 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
