Question about Microwave Ovens
Whirlpool X2-20ES Is it possible to disable/mute the speaker to stop the microwave beeping with each touch of the button, finish cooking, even opening the door!? Cheers
  • Microwave Ovens Master
  • 9,098 Answers
If it's possible to mute or turn down the volume, the owner's manual will cover it.
If not, you may want to take extreme measures, as shown in the video.
Posted on May 03, 2013
  • 108 Answers
SOURCE: GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Posted on Nov 16, 2008
  • 202 Answers
SOURCE: Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Posted on Aug 05, 2009
sclarke7
  • 222 Answers
SOURCE: Microwave will not stop cooking unless I open door
you have a bad door switch call a tech these things can kill you even if they are unplugged.
Posted on Jan 07, 2010
  • 8 Answers
SOURCE: The microwave will start cooking when the door is
there might be a problem in the functional buttons of your microwave.
Posted on Jun 21, 2010
walesarumi
  • 6993 Answers
SOURCE: This morning I pressed the
the fault is from the magnetron of the microwave. The magnetron is gradually becoming defective, that's why you are hearing the buzzing sound. As a matter of fact, the magnetron is the one making that noise. Sooner or later, the microwave won't heat any longer when the case of the microwave gets worse.
First, you need to test the magnetron.
Testing a magnetron:
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor. To learn how to discharge a capacitor, click here: http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
If you cannot perform the above task yourself, ask a family or friend that has the ability to assist you or have a certified and experienced appliance repair technician examine and replace your magnetron. This task is much too dangerous for the average layman to perform on his own.
Regards.
Posted on Sep 13, 2011
How do I stop the beeping when my FRIGIDAIRE microwave finishes cooking?
If you wish to get some details about microwave oven repair and maintenance then check the following link
http://electro-medical.blogspot.com/
Jul 31, 2016 | Frigidaire Microwave Ovens
My Whirlpool WMH31017AS when I plug it in the light comes on and the carousel slowly turns. Buttons don't respond either. It's 14 months old with a 1 year warranty.
I have three customers describe the exact scenario on this MW but was never able to duplicate while on site all three were in warranty I changed the door switches and control board at 14 months they may pay for a service call to have it diagnosed
Jan 13, 2015 | Whirlpool WMH31017AS Over the Range...
Beeping on Sunbeam SGB8901 Microwave
Unplug microwave, open top, "several screws" look to where the keypad is, behind that you should see the control board, mounted you should see a round black device may be a speaker or pizza buzzer, verify that is sound.
May 09, 2012 | Sunbeam Microwave Ovens
There is a beep noise every 60 seconds 24 hours/day... what can we do to stop it? microwave model JTP85WOA2WW serial # zv676667q
My microwave beeps once every minute to let me know that it has finished cooking. If I open the door, then close it, the beep stops.
Jul 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Works fine, except the beeps suddenly went silent. Examples: 1. When food is finished cooking, no beep any longer. 2. When pressing any key to set for cooking, no beeps any longer. Never thought that...
On page 21 of the owner's manual (online here), that's covered under "AUDIBLE SIGNAL ELIMINATION":
If you wish to have the oven operate with no audible signals, touch CUSTOM HELP, the number 2 and STOP/CLEAR.
To cancel and restore the audible signal, touch CUSTOM HELP, the number 2 and START/MINUTE PLUS.
Feb 16, 2011 | Sharp R-1520LW 1000 Watts Microwave Oven
Hi! I like my [2001] Whirlpool MT2110SJQ 1100 Watts Microwave Oven very much, but have been having some occasional problems (possibly due to its age???). The first problem is that occasionally...
Arcing is a sign that the Magnetron is shorting out. Make sure cover, usually plastic, is installed properly covering Magnetron port. It keeps food from entering port. This is a dangerous condition, replace unit.
Mar 07, 2017 | Whirlpool MT2110SJQ 1100 Watts Microwave...
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
Jan 07, 2010 | Amana MVH210W Microwave Oven
Microwave JVM1630
From what you have described, it appears that the microwave oven works fine, except that the beeper doesn't work like it used to.
This could be caused by a couple of things.
First, there is typically a piezo electric speaker that creates the "beeping" sound. It's possible that this part has failed. It's a mechanical device and can break. This part is relatively inexpensive.
The piezo speaker is controlled by the microprocessor board. It's possible that there is a problem with one of the output lines from the microprocessor that is tied to the speaker.
One way to determine which part is defective, is to try connecting another speaker in parallel across the original speaker, or remove the original and try the replacement (least expensive method).
If there still is no sound, then I would suspect the problem is on the microprocessor board. (most expensive method).
If I can be of further assistance to you, please let me know.
Good Luck!
- Jim
Feb 08, 2008 | GE JVM1630 Microwave Oven
Microwave Ovens Logo
137 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
