Question about Beko 24 in. D3421F Free-standing Dishwasher
Beko DE 3762F
Hello out there. I am hoping you can assist me to resolve this problem with my dishwasher. It is just over a year old. It starts and then refuses to move to the next cycle. Any ideas ? Kindest regards, Dave.
  • 1 more comment
  • Dave Stark Aug 08, 2007
    Hi Dovi - thanks for getting back to me so quickly.
    The machine is stuck on pre wash and does nothing....no water comes in and nothing starts.
    Any ideas ?????
  • Dave Stark Aug 10, 2007
    Hi Dovi
    Have given up and called out local repair man.
    I u=suspect it was the water inlet valve but we will soon find out. The little water that was put into the machine did drain but not a lot else happened. Will keep you informed.
  • Anonymous Oct 18, 2008
    same problem,i turn it on, the motors kick in but refuses to move to next cycle.is there a reset that we can do to fix this problem as it happened once before and it sort of fixed itself, we left it switched off for a couple of weeks and when we switched it back on it come to life,however this hasnt worked this time around.looking at most of the comments it seems a regular fault.HELP!!!
  • 641 Answers
Dave, Could you provide more details ? - Does it drain out water at the beginning of the cycle? - Does it fill with water ?
Posted on Aug 07, 2007
  • Dov Dror Aug 08, 2007
    Dave,
    I understand that no water comes in but again it important to know if at the beginning of the process it does drain water out or could you hear pump works.
SOURCE:
Beko dishwasher DSFN1534B shorts and arcs when you open the door. Electrician says it is dangerous. Just over one year old.
Yes very dangerous turn off the power contact makes hotline this maybe under warranty.
May 15, 2017 | Beko Dishwashers
Beko dsfn 1532 start button will not stay down
We have the same problem. How did you resolve this issue?
Dec 30, 2012 | Beko Dishwashers
Beko dishwasher not draining
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Nov 20, 2010 | Beko 24 in. D3421F Free-standing...
Beko 4310 stopped mid wash and no sign of any power. have checked fuse and mains, no problem... machine just over 1 year old... any ideas?
I am assuming it is a beko dwd4310 dishwasher.
If the display has totally blanked off then the control board has packed up.
You can find the part at this site.
Nov 07, 2010 | Beko Dishwashers
Brand new beko DE 2542 PW dishwasher won't start wash cycle
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Good Luck.
May 09, 2010 | Dishwashers
I have a Beko D 2731 FW its about 4 years old and recently it has begun to leave a gritty deposits. I think this may be due to the top spray arm not running as freely as it used to. I would appreciate any...
Here are a few things to check.
* Worn wash impeller (depending on design). Test by placing a glass upright in upper rack with full charge of water in the basin. Run dishwasher for 30 seconds. Glass should fill up. If not, replace wash impeller.
* Debris caught in spray arm holes. Remove spray arm and clean out with water and compressed air.
* Heating element burned out. Check water temp during wash--should read between 130 to 140 F.
* Insufficient water fill in basin. In most models, proper fill level is just up to the heating element. Much less than this will result in poor cleaning.
Hope this helps.
Sep 08, 2009 | Beko Dishwashers
BEKO DE 3430 dishwasher
run it empty with baking soda and vinegar,this should clean everthing,mike
Aug 09, 2008 | Beko 24 in. D3731F Free-standing...
Beko 24 in. D3421F Free-standing Dishwasher Logo
453 people viewed this question
Top Beko Dishwashers Experts
Marvin
Marvin
Paul Carew
Sam Stothers
Sam Stothers
Level 1 Expert
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
