Question about Garden
How to reset fuel pump
No fuel at fuel filter when starting
  • 7,482 Answers
Hi Cezar
You may have a fuel filter plugged, or trash in your carb...maybe this will help you.
Posted on Apr 30, 2013
Car will start but then dies
No fuel supply check fuel filter and fuel pump
Dec 22, 2017 | Cars & Trucks
Is there a reset button on a 2001 chrisler 300m for the fuel pump
There is no reset. Pump may have pulled up residue and clogged the filter. First check pump fuse. If good, replace fuel filter and see if that works. If not, check fuel pressure at the injector rail.
Sep 28, 2017 | Cars & Trucks
My 98 gmc safari starts but won't stay started unless u keep putting gas into the throtal thing behind the airvent I already changed the fuel filter still doing the same thing help
It might be your fuel pump not getting fuel to throttle body. Disconnect fuel line to throttle housing get someone to turn car over and see if fuel is getting pumped up. If not the pump could be faulty or fuel filter blocked. Also check to see if you car has a fuel cut of reset button it could just need a reset.
May 22, 2015 | 1998 GMC Safari
Navara 2003 D22 ZD30(et) fuel pump problem
When you run a Pump Empty, there is no FUEL to keep it cool and you overheat it and burn it up.
I have done many fuel pump replacements and I had 3 in a row that were defective right out of the box..
Fuel Pump and Computer RESET? Never heard of that before
Apr 15, 2013 | Cars & Trucks
2002 olds alero was running then would not start back up.New fuel filter and the fuel pump is fine,but it turns over,won't start
Have you reset the fuel pump switch...bled the lines? Try starting fluid for a few times then look at these issues.
Dec 30, 2012 | 2002 Oldsmobile Alero
Ran out of gas. vehicle started, ran, drove home, turned off, would not restart. Is there a ran out of fuel procedure/fuel pump reset. Does sound like fuel pump is working. Dirty/clogged fuel filter
No, there isn't a reset. When you run out of fuel, after refilling turn your key on without starting the vehicle. You should hear the fuel pump working for a couple seconds. After the pump stops then try to start the vehicle. Because you could hear the fuel pump working, it is possible that your fuel filter is dirty/clogged. I hope this helps.
Mar 21, 2010 | 1993 Mercury Villager
2000 Crown Vic cranks but won't start.
Check the fuel pump reset switch again, if it is popped back out then replace that little switch in the trunk, any ford one will do. it works off a magnet and a bearing to close the circuit for the fuel pump. easy fix.
Oct 05, 2009 | 2000 Ford Crown Victoria
2002 Madza 626 4cyl car will not start. Has spark
It could be: clogged fuel filter, bad fuel pump, or the cutoff switch. Could be fuel pump relay. It's in the engine compartment fues block, and labeled "Fuel Pump"
If it's either the filter or the pump, replace both at the same time, it's cheaper.
The fuel cutoff in located in the trunk, along the driver side rear fender, you have to pull all the carpeting and such out on that side to get to it. It's marked "Fuel cutoff" Not sure on the 626, you might just have to push the reset button on the module.
However I doubt this is your problem I would think it's either the relay, the filter or pump.
Mar 06, 2009 | 2002 Mazda 626
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
