Question about Microwave Ovens
Goldstar gr 242 BDS model double door model - Microwave Ovens
Oven quit working on model mv-1320w
That would be a defective door switch, most likely the bottom one.
(It's either the top or bottom switch (not the middle one) and whichever one has thicker wires, not the one with the thinner wires.)
See my help text file on door switches here.
To order other Goldstar / L.G. parts besides door switches, visit Encompass. You'll probably have to call them at 866-779-5835 to get part numbers.
Nov 27, 2012 | Goldstar Microwave Ovens
On a goldstar microwave oven model mv-1500mg, after pressing the light button, there was a bang and then no power to anything. I have checked the electrical outlet and there is no problem. Thanks for your...
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 19, 2010 | Goldstar MV-1526 Microwave Oven
I have a goldstar microwave oven mfg during 1988. Model # ER-76IM. Can you tell me the wattage of this microwave.
I can't find any info on this model probably due to its age, but there should be a data plate or sticker located either (1) on the back, near the cord (2) side (3) inside back or side wall (4) on the door or door jamb of the oven. Failing this, that next step would be to contact Goldstar in the method of your choice from the webpage below:
http://www.goldstarappliances.com/contact-us.html
I hope this helps & good luck!
Feb 12, 2010 | Microwave Ovens
Goldstar microwave need to change the door frame help!
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 15, 2009 | Goldstar Microwave Ovens
Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Dec 10, 2008 | Goldstar MV-1155 Microwave Oven
Goldstar NV1502 No Heat
You should still have about a 5-year warranty on the magnetron, if that's the trouble.
If everything else works, it's almost certainly a high voltage component, most likely the magnetron or diode, but also possibly the transformer.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
I would contact LG / Goldstar first. For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 05, 2008 | Goldstar MV-1501 Microwave Oven
Plastic shielding and door handle broke off
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
If you don't find your model there, call the number shown on that page.
Oct 12, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar Microwave MV1501w
Chances are the panels separate as shown in the photo I have attached below.
Panel replacement can usually be done without removing the door from the microwave.
In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges.
I generally do not advise removing the hinges from the microwave.
Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in.
Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices.
By the way, where did you get the part? I'm trying to find a good Goldstar / LG source to recommend.
Aug 16, 2007 | Goldstar MV-1155 Microwave Oven
Goldstar 1500m
The most common causes for this (in order) are a defective door switch, door switch mount, or a bad connection or relay on the control panel. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
May 25, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
