Question about KitchenAid KSC6223 Slow Cooker, 6 Qt
Error code E1
Have used this slow cooker 5 times since got about a month ago and 2 times the cooking stops. This time it showed E1 message.
I have an all clad pressure cooker I need to know how long to cook a 5 pound pork roast for pork tocos
Hi Sharon! If you want the seasonings to get all thru the meat, I would cut it into about 6 pieces. Add your seasonings and cook it for 20 - 25 minutes. I have been cooking for 50 years and bought one of the electric digital pressure cookers. Liked it so much I bought another one. I made a pork roast about 2 weeks ago and I cooked mine for 25 minutes, It was so tender I could pull it apart with dinner forks. The seasonings I used were fresh diced onions ( 1 med) 2 cloves fresh garlic diced, salt and pepper to taste. Hope this helps.
Jan 24, 2016 | Crock Pots & Slow Cookers
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    I have Ronson slow cooker with no manual, it has settings 1,2 qnd auto. Which is high and low, and what does auto setting do>
    I also have a Ronson slow cooker.
    Instructions from the book read as follows:
    - On setting 1 (low), the slow cooker can operate all day and night if required.
    - When set to 2 (high), it is very much like a covered pot on the stove. Foods will cook in half the time required for 1 (low).
    - When set to auto, the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature, then switches to 1 (low) and maintains a constant slow cooking temperature. Auto is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
    I always use the auto setting, unless I don't have as much time, and will then use setting 2.
    Sep 15, 2010 | Crock Pots & Slow Cookers
    Slow cooker will only stay on warm. How do I put
    This slow cooker has 3 settings LOW, HIGH, & WARM
    When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
    If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
    Feb 11, 2010 | CorningWare SC60 Slow Cooker
    How do I start the cooker on low?
    The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
    The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
    If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
    To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
    If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
    Dec 18, 2009 | CorningWare SC60 Slow Cooker
    Need a manual for the corningware sc60
    The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
    Nov 28, 2009 | CorningWare SC60 Slow Cooker
    Can't change temperature-stays on "warm"
    Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
    May 19, 2009 | CorningWare SC60 Slow Cooker
    Need directions for presidents choice slow cooker
    Heat intensity is warm, 1, 2, 3 (highest)
    How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
    Apr 11, 2009 | Crock Pots & Slow Cookers
    When I turn it on I get E01
    1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
    2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
    3. 2. Plug the unit back into the wall socket.
    4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
    Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
    KitchenAid KSC6223 Slow Cooker, 6 Qt Logo
    119 people viewed this question
    Top KitchenAid Crock Pots & Slow Cookers Experts
    charles
    Irene Tulloch
    Are you a KitchenAid Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
