Question about Dishwashers
Help me No water turns on just no rinse
    Problem Solver:
  • 17 Answers
If you have water for washing the dishes and only the rinse water will not flow then the problem is likely a defective timer control. The timer send signals to the washer for all of its basic function to start and stop. Bad timers are a common problem, especially with an older machine, but they can also go bad in a new machine. f the dishwasher is under warranty follow the warranty service steps to get local free repair. Otherwise you may have to purchase and install a new timer yourself or hire someone to do this at an appliance shop.
Posted on Apr 29, 2013
  • jeremylja901 Apr 29, 2013
    Thanks, there's little water barely any has a burning smell when ran to long not sure
Amana washer will not go through rinse cycle
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 28, 2015 | Amana Washing Machines
Samsung WA12F5L4. Got 4e error. Machine set to wash rinse and spin. When it reaches the rinse cycle, the tub fills, it start rinsing, but the water keeps flowing, it doesnot turn off. Help please. Jus
this could be the water valve getting stuck on. you may need to replace the valve in question (hot or cold). it could be the pressure sensor that tells the machine when to stop filling. check there are no obstructions to the pipe leading to the pressure sensor, then replace the sensor (or board it is on)
Dec 08, 2014 | Samsung Washing Machines
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
Maytag LSE7806ACE washer won't rinse. Machine fills with water and agitates, spins also. Just won"t rinse......help!!!!!!!
Your washer uses cold water only for the rinse cycle.
Start you washer and put the water temperature switch on 'cold' to see if you have any cold water.
If you find that there is no cold water then turn the water off and remove the cold water hose from the back of the washer.
Once you have the cold water hose removed you will be able to look in the water valve and check the screen. A lot of times the screens get plugged up and need to be cleaned. The screen will just pull out of the valve so you can rinse it out good.
Make sure to put the screen back in place.
If you have no cold water and the screen is clean then you will need to replace the water inlet valve.
Aug 03, 2011 | Washing Machines
Will not go through rinse cycle. Just hums.
Try putting unit on cold water wash///just to see if cold water is coming in to machine.... You see the rinse cycle uses only cold water the hum you here is most likely cold water valve..to fix turn water of remove water inlet line (cold) clean water inlet screens( there is also screens inside the valves) hook back up turn water on check for leaks test .If this helped you please vote/// need more help please ask....
Feb 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Bissel Proheat Pro-tech. When turn ON the motor running but not work. The belt still good but tho rotor not turn. Please help me to fix.Thanks
Is this the carpet cleaner Proheat?
I have a Proheat 2X and it wouldn't disperse water unless I used the Water Rinse setting. I found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 23, 2010 | Bissell 9200 Upright Vacuum
MISSED RINSE on culligan softner
the unit number one needs to be reprogrammed by a professional only it is tricky and ck the motor in the unit this controls the valves turning and water direction control.
Apr 29, 2009 | Culligan Sediment Water Filter
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Dishwashers Logo
52 people viewed this question
Top Dishwashers Experts
