Question about Radio Communications
Finding replacement fm radio headset for Lynxx X2 with unusual port
Cannot find replacement headset with matching male jack for older "non-traditional" port on Lynxx X2
2 Suggested Answers
  • 13 Answers
SOURCE: nokia x2-00 headset not working
awdwadawd.lj.jk,jfghfghdrg
Posted on May 21, 2011
How can I listen to the radio without the head set?
Hi Arthur, unfortunately you can't as the wired headset acts as an antenna!
Since the FM radio uses the provided wired stereo headset as its antenna, before opening the application, connect the headset to your phone's the audio jack.
9.3.1 Opening the FM Radio
1. On the Home screen, touch
2. The first time you open FM radio, touch Auto tuning, which automatically scans for
available FM channels, saves them as presets, and plays the first FM channel
found.
May 01, 2016 | Huawei Cell Phones
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
How can I get a replacement headset for my phone ?
take it to a radio shack store and show it to them. they will educatie on what to purchase without guessing at it.
Nov 19, 2014 | Cell Phones
Why radio does not work with headset plugged in
Well there are a few possiblilities:
1 - If the headset is not an OEM part then the wiring or jack may not match or the impedances may be mismatched.
2 - When you say doesn't work you need to be more specific.
VOX capable y/n, VOX Working y/n, PTT on head set y/n, etc.
3 - Has the radio phone/mic jacks ever been modified?
Good Luck with the testing
Jun 22, 2014 | Motorola Mag One BPR40 Two Way Radio
Bose Wave Radio/Kindle Fire
Yes, all you need is a standard audio adapter cable that plugs into the earbud jack on the kindle and into the "variable in" jacks on the back of the Bose. (male stereo 1/8" plug to a pair of male RCA/phono plugs).
Dec 11, 2013 | Bose Black Wave Am/fm Radio W/ Remote -...
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
What output jack should a wireless headphone system be connected to for use by a hearing impaired person, while still allowing sound fron the external speakers for others in the room to listen to? The...
The REC OUT jacks on the back are usually the best as they are not affected by the system volume. You'll need an RCA L and R Male to Headphone (1/4" female) adapter (available at Radio Shack and online sellers).
Jan 03, 2011 | Yamaha RX-V730 Receiver
How can I hook this cam up to my Television?
For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
Nov 04, 2009 | Canon ES75 Camcorder
How to hookup kindle to car audio system
This could be either very easy or a huge headache.
Easy way - The newer cars have an audio input jack, basically a headphone jack (1/8"). There are cables that you can use with 2 male connectors; one on each end. Set your car radio on AUX/LINE IN/MP3 and turn it up.
Hard way - Go to Radioshack or Best Buy, even Target or Wallmart, and buy an FM Transmitter. They shouldn't run over $20. You plug it into you cigarette outlet for power and/or takes 2 AA batteries. Plug the headphone jack into your Kindle and set the radio station on the transmitter to either a very low or very high radio station; somewhere where there is no station close by. Turn the car FM radio to the station you set it on and turn it up.
Sep 18, 2009 | Amazon Kindle 2
How do I connect an mp3 to my 2008 sonata?
The 2008 Sonata does not come equipped to plug in a separate MP3 player. The MP3 on the face of the radio/CD player refers to the fact that the CD player will play MP3 files. If you want to play from a separate player, you will have to add an FM modulator or something similar.
Apr 11, 2009 | 2008 Hyundai Sonata
Radio Communications Logo
32 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
