Question about Kenmore Stove / Oven / Range Bake Element 9758519
Kenmore stove model 62946795891 what is message green square on oven
Oven won't work, has error message of a green square with two red lines, one at the top and one at the bottom of the green square. What is this telling me? Is there a fuse in the stove that has blown? No circuit breakers were thrown.
fridgetech
  • 473 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 11, 2007
reg501
  • 413 Answers
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Posted on Jun 22, 2008
jyackle5
  • 8197 Answers
SOURCE: Kenmore wall oven (model 911.41065690). Works fine
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
good luck
Posted on Sep 30, 2009
  • 400 Answers
SOURCE: kenmore microwave oven model 665 4438955 just
I am not familiar with this particular model, however there are a few things you could check. Do you get any lights or indications at all? Inside (unplug before removing cover) there is probably a fuse. If it is blown, you can replace it as it might have been blown by a power surge, however you should check to see if there is another bad component, especially if it blows a second time. There is generally a transformer, a capacitor and a diode in the power supply, and a magnetron that does the real work. If anything is burned or blackened, this may be your problem, or it could merely be an indication of another shorted component. Using a multimeter, you can check the magnetron. Measuring between the two terminals, you should see very low resistance. This is the filament. From either pin to ground you should see infinite resistance. Anything less and your magnetron is bad. The diode should measure relatively low in one direction and infinite or close to it in the other. The capacitor should start low and build to infinite (as it charges). Most people should just replace the fuse, if bad, and let a technician find any other problem. My built in was worth ordering a new magnetron. Some of the cheaper counter top units might not be worth fooling with. I hope this has helped you.
Posted on Nov 01, 2009
  • 457 Answers
SOURCE: Hi kenmore model 587.15102800 dishwasher not
if the breaker is fine then the next check will be the terminal box on dishwasher. usually that is where you would find your problem. let me know if this helps and if it did help me by sending a 4 thumbs up post Thanks!
Posted on Mar 01, 2010
My ariston oven won't turn on. The stove works and
check and see if the broil works in the oven ,2 if it turns on meaning the element in the top turns red then this generaly means both side of the switch are good. and you need to replace the element on the bottom of the stove.now turn off the stove .1st unplug the stove. 2nd there are 2 screws at the back of the stove on a metal plate which is attached to the element take them off.3rd gently pull out the element about 3 inches until you see 2 wires. there are 2 ways the wires could be connected either push on or by screws if you dont see a screw abviusly its push on. just grab the end of the wire ON the connecter and grab the elemnt at the connecter and wigglethe connector back and forth while pullin on the connecter. wala. now locate the model number and go to amazon.com or your local parts house and install in reverse
Aug 20, 2012 | Ovens
My stove is about 43 years old and the round red igniter broke. I need a new onefor magic Chef Model#TZ-800C-3WP.Can I get a new one?
Hello Barbara,
Is the ignitor you need for the oven, stove top surface burners. If for the oven is it about a inch or so in round diameter and about 4-6 inches long with 2 wires to it and glows when oven is turned on?
the very old ignitors for the oven was a square/rectangle glow plug about a inch or so square
Which best describes the one you need?
Gene
Aug 09, 2011 | Magic Chef Ovens
Says oven door is locked...it is not. none of the buttons respond and oven won't work. stove top does work. what could be the problem?
I had the same problem with my oven.Mine is a different make and model but try by opening your ovenand move your locking lever for cleaning look at the actuall hook that locks it and find where on the oven itlocks into sometimes there is a safety switch in that hole that gets stuck.Try by messing with the safety switch with a screwdriver or something to see if the door off light goes off.Good Luck.
Jul 17, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
My kenmore oven's led display works, but will not heat
pull stove out and check the volts either on the plug or terminal block on the stove where the wires are terminated. check the terminals marked L or line at the same time should have 240 volts if not your breaker which probably is a 40amp will need replacing
Sep 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Stove / Oven / Range Bake Element 9758519 Logo
44 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
