Question about Coleman Lantern Fan Radio (841.321) AM/FM
Vdc power adapter - Coleman Lantern Fan Radio (841.321) AM/FM
I need a wire diagram for a bunker hill security camera
Yellow is for the microphone
Blue is for the camera
White is the COMMON GROUND
Orange is the power (7.5 VDC @ 300 mA (9 VDC will work))
Link to the user manual: http://manuals.harborfreight.com/manuals/47000-47999/47546.pdf
Aug 13, 2014 | Computers & Internet
My gateway e-475m g laptop will not come on or charge. i have 17.6 vdc coming out of the ac power adapter
If your power cord/charger is putting out the right amount of power then it's probably your motherboard that needs to be replaced.
Jun 27, 2012 | Amstron Gateway E-475M G Laptop AC Power...
Problems with bose companion II 12 volt adapter
I found that the 12v power pack from an external hard drive works fine. I think you need the 5.5 x 2.5 mm plug.
Jun 12, 2012 | Bose Companion 2 Series II Multimedia...
The dsi flt light will not stay off. water heater is being used by electricity only and gas is off. what do we do and whar is cause of this.
The dsi light is powered by 12 volts, either from trailer converter, or a plug in to a receptacle that converts it to 12 VDC. It sounds like a faulty switch, if you switch it to off and it doesn't go off. . Temporarily, you can pull switch out and disconnect 12 VDC power at spade connector on switch. Be sure to wrap electrical tape around bare spade (female) that has incoming 12 VDC, until you replace switch. Is the water heater actually trying to ignite on gas when light is on? If you don't want to pull switch, look for fuse in fuse panel for water heater, or under counter or wherever, near water heater area for an adapter plugged in with wires running to the water heater and simply unplug the adapter at the receptacle.
Jan 09, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have been told that the vx510 card processor can be run off of a UPS for occasions when AC power isn't available. I cannot find power consumption figures on the vx510 excep for a voltage rating of...
The vx510 operates with a power adapter. The 115VAC is what the adapter plugs into, and the DC numbers are for the output to the actual machine. Basically you just plug the power adapter into the UPS and it's already plugged into the machine...just like a laptop, etc.
However...the figures your are quoting of 22-26VDC at 1.5 amps do not agree with Verifone's published specs for the vx510 of 9.4 VDC at 4.0 amps (link to product specs page). I'd be very careful.
Hope that's helpful.
Jan 06, 2011 | Computers & Internet
I have a toshiba LT a205; the LED flashes 6x; what does that mean? the psu is rated at 19vdc, and puts out 18.5 vdc. The end of the power connector that goes to the mb only has 0.5 vdc on it, so I'm...
19volts is a nominal value. The AC Adapter will be fine from 18 volts up to 20volts because the power unit on the motherboard regulates the voltages very accurately.
You say you only have 0,5volts on the Mother Board power input. There's your fault. Between the Mother Board socket and the AC Adapter.
Replace the AC Adapter or Laptop Connection lead if you mean there is 0.5volts actually on the Mother Board but full oiutput from the Adapter.
Dec 15, 2010 | Toshiba Satellite A205-S4777 Notebook
I misplaced the power adaptor, and found one the fits in, but don't know if has the coorect powers output.. the power adaptor I have for this I rocks IR 4300 is an eblue mainstay with an output of 5.0...
as per irocks page this is the power info for your device:
Power : Self Power : 5V
Adapter : (input)100~240 VAC , (output)5 VDC
you probably may want to check with someone at radioshack if the adapter you found matches above specs
info on your device can be found here
Dec 26, 2009 | i-rocks IR-4300 4-Port USB Hub
THE SMARTDISK 80 GB MODELUSBFLB80-C WILL NOT WORK WITH USB.THERE WASN'T A 5 VDC POWER ADAPTER. wHAT IS THE SPECS FOR THE 5 VDC APAPTER
Make sure you are connecting it to a usb 2.0 port. Usb 2.0 will supply the 5v power the device needs. also use the cable that came with the drive. some drives plug into 2 usb ports.
Nov 30, 2009 | SmartDisk FireLite 80 GB Hard Drive
1212hr power supply
The device runs on 5 VDC. There was an optional adapter available that used the keyboard output, that simply tapped the GND & +5 VDC. On the jack, the interior is +5, the outer contact is GND. The easiest way to power the device is to tap into a free line from your computer power supply. Alternatively, a transformer with 5 VDC 100 mA output should do the trick.
Apr 03, 2007 | Genius NewSketch 1212HR (K9436401)
Coleman Lantern Fan Radio (841.321) AM/FM Logo
71 people viewed this question
Top Coleman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Coleman Audio Player and Recorder Expert? Answer questions, earn points and help others
